  • Peavey P1BT All-In-One Portable PA System
CLEARANCE Peavey P1BT All-In-One Portable PA System
PeaveyPart # 248-9924
Model: P1BT
Introducing the Peavey P1BT All-In-One Portable PA System, your go-to solution for high-quality sound on the go. Combining Peavey's legendary audio engineering with the convenience of portability, the P1BT offers a seamless audio experience for any occasion.
  • Leverages Peavey's audio expertisefor clear, powerful sound in a compact package
  • Not only Bluetooth compatible, but can pair with a second unit for stereo sound
  • Lightweight, durable, and compact to reduce footprint on stage
  • Intuitive onboard controls for easy sound adjustment and customization
  • Offers hours of performance time on a single charge, making it ideal for outdoor events and places without easy access to power outlets.
  • Compatible with a guitar, microphone, turntable, or any other audio source
CLEARANCE $279.99
MSRP: $329.99
Save $50.00 (15%)
1 In Stock
We'll send you an email when Peavey P1BT All-In-One Portable PA System is back in stock or available for preorder.
Order in the next 4 hr 37 min to ship today. Details
Introducing the Peavey P1BT All-In-One Portable PA System, your go-to solution for high-quality sound on the go. Combining Peavey's legendary audio engineering with the convenience of portability, the P1BT offers a seamless audio experience for any occasion. Whether you're addressing a crowd, performing at a small venue, or entertaining at a private event, this system delivers clear, powerful sound. With Bluetooth connectivity, easy setup, and a user-friendly interface, the P1BT is perfect for performers, speakers, and event organizers seeking reliability without the hassle.
Don't let the compact size fool you; the P1BT packs a powerful audio punch. Utilizing Peavey's renowned sound engineering, this system delivers crisp highs, clear mids, and rich lows, ensuring every note and word is projected with clarity and precision.
The P1BT's Bluetooth connectivity opens up a world of wireless audio streaming. Easily pair your mobile device to play background music or backing tracks without the need for cords and cables, keeping your setup clean and simple.
Mobility is at the core of the P1BT design. Its lightweight build and built-in handle make it a breeze to carry from gig to gig. Whether you're a traveling musician or a mobile DJ, this system goes wherever you go without weighing you down.
The P1BT is equipped with versatile input options, accommodating everything from microphones to musical instruments. Onboard controls for volume, EQ, and Bluetooth pairing are straightforward and accessible, making on-the-fly adjustments a snap.
Freedom from power outlets allows you to perform anywhere. The P1BT's rechargeable battery offers extended playtime, ensuring your event goes off without a hitch, even in locations without direct power access. Enjoy the peace of mind that comes with knowing your PA system will last as long as your performance does.
  • Bluetooth stereo linking
  • Bluetooth audio input for streaming music from any Bluetooth device
  • 3 Channel mixer
  • 2 XLR mic inputs and 1/4" Line Inputs
  • RCA/3.5 mm Stereo input channel
  • 180 Watt Max
  • 2x6.5" Woofers with 1" (25mm) high-frequency compression driver
  • Maximum Output: 98dB SPL (1W/1M)
  • Dimensions: P1BT 23" x 9.25" x 10.5" (584mm x 235mm x 267mm)
  • Weight: 15.4lbs (7kgs)
  • Power Input: 120VAC/60Hz or 230VAC/50Hz
BrandPeavey
ModelP1BT
Part Number248-9924
UPC014367670196
Weight15.4
Configuration2-way
Speaker TypeActive / Powered
Woofer Size6.5"
