  • Peavey 18" Lo Max RB Replacement Speaker Basket
CLEARANCE Peavey 18" Lo Max RB Replacement Speaker Basket
PeaveyPart # 294-3138
Model: 18" Lo Max RB
Specifications: • Impedance: 8 ohm • Power capacity: 4800 watts peak, 2400 watts program, 1200 watts continuous • Sensitivity: 97.1 db • Usable freq. range: 30 Hz - 500 Hz.
We'll send you an email when Peavey 18" Lo Max RB Replacement Speaker Basket is back in stock or available for preorder.
Peavey item 00560410.
Specifications: • Impedance: 8 ohm • Power capacity: 4800 watts peak, 2400 watts program, 1200 watts continuous • Sensitivity: 97.1 db • Usable freq. range: 30 Hz - 500 Hz • Cone: Kevlar® impregnated cellulose • VCdia: 4.0" / 100 mm • Voice coil material: Polyimide coated copper ribbon wire Polyimide-impregnated fiberglass former Nomex® stiffener Solderless diffusion welded OFHC copper leads • Znom: 8 ohms • Revc: 6.10 ohms • Sd: 0.1237 sq. m • BL: 25.51 T/M • Fo: 33.5 Hz • Vas: 294.7 L • Cms: 135.6 uM/N • Mms: 167.9 gm • QMS: 8.741 • Qes: 0.330 • Qts: 0.318 • Xmax: 8.25 mm • Le: 0.751 mH • SPL: 97.1 1W/1m • No: 3.21% • Vd: 128.7 cu. in./2110 mL • Pmax: 2400 watts pgm. • Disp: 284 cu. in./4655 mL.
BrandPeavey
Model18" Lo Max RB
Part Number294-3138
UPC014367124392
Weight7.2
