Peavey 14T Titanium Compression Driver 1-3/8"-18 TPI
We'll send you an email when Peavey 14T Titanium Compression Driver 1-3/8"-18 TPI is back in stock or available for preorder.
Specifications: Sensitivity: 105 dB 1W/1m (on-axis, 90º x 45º horn) • Frequency response: 1,500 - 20,000 Hz • Recommended crossover: 2,000 Hz at 12 dB/octave • Power handling (1000 - 20,000 Hz): 100 watts peak; 50 watts program; 25 watts continuous • Diaphragm: commercially pure titanium • VC dia: 1.4" / 34.4 mm • Voice coil material: copper clad aluminum (CCA) wire on an aluminum former • Dimensions: 3.44" diameter x 2.30" (87.4 x 58.4 mm) • Coupling Threads: standard 1-3/8" - 18 TPI • DCR: 6.4 ohms • Nominal impedance: 8 ohms • Weight: 33.0 oz. • Lowest recommended crossover: 1,800 Hz at 12 dB/octave.
Product Details | |
| Brand | Peavey |
| Model | 14T |
| Part Number | 294-3128 |
| UPC | 014367604450 |
| Unit of Measure | Each |
| Weight | 2.14 |
Product Specifications | |
| Diaphragm Material | Titanium |
| Exit Diameter | 1" |
| Mounting Type | 1-3/8"-18 TPI |
| Power Handling (RMS) | 50 Watts |
| Impedance | 8Ω |
