  • Passive Dayton Audio Reference 15" with Dual Passive Radiator Subwoofer Kit 800 Watts
CLEARANCE Passive Dayton Audio Reference 15" with Dual Passive Radiator Subwoofer Kit 800 Watts
Parts ExpressPart # 300-7156
Model: 300-7156
With unassisted response down to 20 Hz and incredible output capability, this 15" passive radiator assisted subwoofer kit is an excellent addition to large music and home theater systems. Using Dayton Audio's RSS390HO-4 driver teamed up with a pair of the matching RSS390-PR passive radiators, this kit will not only deliver high output but distortion is remarkably low too.
  • High excursion RSS390HO-4 driver delivers powerful bass response with low distortion
  • Passive radiator assisted design extends bass response and keeps enclosure small
  • Perfect for use with high power music and home theater systems
  • Customize the precision CNC-cut MDF enclosure to fit in any decor
For ultra-low frequency reproduction, powerful output capability, and incredibly low distortion, building this passive 15” subwoofer kit is an obvious choice. Using the popular Dayton Audio Reference Series RSS390HO-4 15” aluminum cone driver and two of the matching RSS390-PR  15” passive radiators, this subwoofer kit is an incredibly potent combination. With an unassisted response down to 24 Hz and capable of over 112 dB of output, you can expect earth shaking bass response without the high distortion that can result from applying massive amounts of bass boost.
Features:
  •  Customize the precision CNC-cut MDF enclosure to fi t in any decor
  •  CNC cut MDF enclosures are easy to assemble with minimal tools
  • This kit will not only produces high-output, it delivers remarkably low distortion as well
Customer Comments:
"Love it, its blends well... and has all of the oomph I could want" -Anthony F. ⋆⋆⋆⋆⋆
"Awesome sub. Adds a whole new dimension to movies."  -Bill Mahar S.  ⋆⋆⋆⋆⋆
"The subwoofer itself sounds great and is insanely powerful."  -NYCJay ⋆⋆⋆⋆⋆
"This sub... will get down around 20 hz... the passive radiators give you the best of both worlds" -New User U. ⋆⋆⋆⋆⋆
Meet the Designer:
Chris Perez
His passion for superior audio kits is surpassed only by his love for  imaginative outdoor light displays.
Customer Projects:
Kit Includes:
Part #QTY.Description
295-4691 Dayton Audio RSS390HO-4 15” Reference Series HO Subwoofer 4 Ohm
295-504
2 Dayton Audio RSS390-PR 15” Reference Series Aluminum Cone Passive Radiator
260-5201 Sonic Barrier 1/2” Acoustic Sound Damping Foam with PSA 18” x  24
-1 Knock down enclosure
Additional Parts Used:
Part#QTY.Description
081-422- #8 x 3/4” Deep Thread Pan Head Screws Black 100 Pcs.
081-425- #8 x 1” Deep Thread Pan Head Screws Black 100 Pcs.
092-0541 Neutrik NL4MPR Speakon Connector 4 Pole Round Chassis Mount
081-3220-#4 x 5/8” Flat Head Wood Screw Zinc
095-808- Gold 12-10 AWG 0.187" Female Disconnect 5 Pair
100-065- JSC Wire 12 AWG Red/Black Zip Power Speaker Wire
  • Power: 800 watts RMS
  • Subwoofer: 1 x Dayton Audio RSS390HO-4  15" Reference Series HO Subwoofer 4 Ohm
  • Frequency response:  21 – 600 Hz
  • SPL: 92.8 dB @ 2.83V/1m
  • Xmax: 12.0mm
  • Dimensions:  19.25" H x 19.25" W x 20" D
Model300-7156
Part Number300-7156
UPC848791005589
Weight89.6
Cabinet Dimensions (HxWxD)19.25" x 19.25" x 20"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
ConfigurationSubwoofer
Input Rating4 ohm
Speaker TypeSubwoofer
Woofer Diameter15"
