Add a little color to your sound, in a good way, with PRV Audio's WGP14-50 pink chrome finished exponential horn. A standard 4-bolt flange is compatible with most 2" compression drivers. This horn, constructed from non-resonant recycled plastic and finished in a UV resistant coating, is perfect for outdoor or automotive use. Acoustic loading is maintained down to 600 Hz.
Specifications:• Horn type: Exponential • Minimum frequency: 600 Hz • Nominal dispersion: 45° H x 45° V • Throat diameter: 2" • Mounting type: 4-bolt • Dimensions: 6.825" dia. x 5.25" D • Cabinet cutout: 4.75" dia.
