  • PRV Audio WG270Ph 1" Phenolic Compression Driver 8 Ohm
PRV AudioPart # 294-3010
Model: WG270Ph
PRV Audio's WG270Ph horn loaded midrange pairs the updated and improved D270Ph-S 1" phenolic exit driver with the WG11-25 compact 45° x 45° exponential horn. This combo, built for high output, low distortion vocal reproduction down to 500 Hz, is the perfect solution for use in high output PA and pro audio on wheels systems.
  • 2" phenolic diaphragm provides extreme clarity in the critical mid or vocal range
  • Compact driver design for easy front mount installation
  • New and improved design based on our D250Ph-S
  • Ideal horn and driver combo for mid-range and vocal reinforcement
  • Compact horn size is perfect for conditions where space is a concern
Your Price: $39.91
Save $9.98 (20%)
We'll send you an email when PRV Audio WG270Ph 1" Phenolic Compression Driver 8 Ohm is back in stock or available for preorder.
Combining the D270Ph-S 1" phenolic exit driver with the WG11-25 compact 45° x 45° exponential horn, the compact WG270Ph horn loaded mid/tweeter from PRV Audio was built to fulfill the demand in the market. The small diameter of the driver provides front mounting without detaching the driver from the horn, making it effortless to install into tight spaces. The high-temperature copper wire used for the voice coil is wound on a Kapton former to withstand high operating temperatures. The old replacement diaphragm RPD250Ph still fits the D270Ph-S driver. The nearly-indestructible phenolic diaphragm can play down to 500 Hz and resists the elements, making it ideal for outdoor use.
Designed to reproduce the all-important vocal range with authority, this mid-range compression driver and horn is an excellent choice for high power public address (PA) Systems small venues and gymnasiums. Car audio SPL enthusiasts use this combo for vocal reinforcement on 3-way systems.
BrandPRV Audio
ModelWG270Ph
Part Number294-3010
UPC602938022439
Weight3.05
Diaphragm MaterialPhenolic
Exit Diameter1"
Mounting TypeN/A
Power Handling (RMS)75 Watts
Impedance8Ω
