  • PRV Audio WG2200Ph SLIM 2" Midrange Compression Horn Driver with SLIM Horn
PRV AudioPart # 294-3514
Model: WG2200Ph SLIM
1 Question, 1 Answer or
Introducing the WG2200Ph SLIM, a compact horn + driver solution designed for midrange vocal reproduction, boasting high sensitivity and delivering a pleasant sound through its phenolic diaphragm. With its high output and smooth midrange frequency response, this horn driver is versatile, suitable for a wide range of high-output audio applications for vocal reinforcement, including PRO, Home, Car, or PROAudioOnWheels® Audio Systems.
  • Phenolic diaphragm with 2″ Voice Coil, providing dynamic output along with excellent efficiency – 107 dB Sensitivity
  • D2200Ph Midrange 2″ Exit Driver + Shallow Horn WGP14-50X – Perfect as vocal compression driver for car audio
  • Designed for midrange and vocals from 800 to 9,000 Hz
  • PRO Audio horn driver, able to handle 200 Watts Continuous Program Power (RMS) with music
  • Compact driver mounted on slim horn, ideal for tight spaces, increase sound output on your system with this slim solution. Great choice for custom car audio door panels
Your Price: $79.91
MSRP: $99.89
Save $19.98 (20%)
We'll send you an email when PRV Audio WG2200Ph SLIM 2" Midrange Compression Horn Driver with SLIM Horn is back in stock or available for preorder.
Order in the next 12 hr 28 min to ship today. Details
Featuring a nearly indestructible Phenolic Diaphragm structure specifically engineered for vocal reproduction, this driver excels in reproducing the critical vocal range from 800 Hz. Its robust design ensures enough output to complement even the most powerful low-frequency speakers.
Featuring a small diameter, this driver facilitates front mounting, simplifying installation without the need to detach it from the WGP14-50X Horn. Drawing PRV’s wealth of experience and dedication to customer satisfaction, we've developed a compact yet remarkably powerful driver. This solution addresses critical concerns regarding component spacing and weight, ensuring optimal performance and ease of installation.
TRIO by PRV harnesses cutting-edge Brazilian phenolic technology meticulously crafted for superior vocal reproduction. Its phenolic diaphragm is intricately attached to a 2" diameter copper-clad aluminum wire with Kapton® former, enabling a robust 200 Watts RMS musical power handling. For optimal performance, pair with the recommended HPF using PRV Digital Signal Processor DSP.
BrandPRV Audio
ModelWG2200Ph SLIM
Part Number294-3514
UPC810075523904
Weight7.5
Diaphragm MaterialPhenolic
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)200 Watts
