  • PRV Audio WG175PY-Nd-4 Driver Horn Combo 4 Ohm
PRV AudioPart # 294-3550
Model: WG175PY-Nd-4
The PRV Audio WG175PY-Nd-4 Driver Horn Combo is designed to deliver exceptional sound clarity and efficiency, making it a perfect choice for both professional audio setups and high-performance car audio systems. This 4-ohm driver and horn combination features a neodymium magnet and a lightweight yet durable construction, ensuring powerful audio output with minimal distortion. Its compact design allows for easy integration into various audio configurations, providing a versatile and high-quality sound solution.
  • 4-ohm driver horn combo with neodymium magnet for enhanced performance
  • Delivers clear and powerful sound with high efficiency
  • Ideal for professional audio systems and high-performance car audio setups
  • Compact and lightweight design for easy installation
  • Durable construction for long-lasting reliability
Your Price: $79.91
Save $19.98 (20%)
We'll send you an email when PRV Audio WG175PY-Nd-4 Driver Horn Combo 4 Ohm is back in stock or available for preorder.
The PRV Audio WG175PY-Nd-4 Driver Horn Combo stands out with its advanced engineering and high-quality components, designed to produce accurate and detailed sound. The neodymium magnet provides a strong magnetic field, ensuring excellent transient response and high efficiency. This driver and horn combination delivers crisp, clear audio across a wide frequency range, making it a valuable addition to any sound system.
Perfect for applications where sound clarity and efficiency are paramount, the WG175PY-Nd-4 is versatile enough to be used in both professional PA systems and high-end car audio setups. Its compact design allows for easy integration with existing audio components, while its robust construction ensures reliable performance even in demanding environments. Upgrade your audio system with the PRV Audio WG175PY-Nd-4 Driver Horn Combo and experience superior sound quality and powerful output.
Built to last, the PRV Audio WG175PY-Nd-4 features a durable design that withstands rigorous use, ensuring long-lasting reliability. Whether you're looking to enhance a professional sound system or upgrade a car audio setup, this driver horn combo offers a high-performance solution that meets the demands of any audio enthusiast. Experience the difference with the PRV Audio WG175PY-Nd-4 Driver Horn Combo and elevate your sound system to the next level.
BrandPRV Audio
ModelWG175PY-Nd-4
Part Number294-3550
UPC810075522976
Weight0.95
Diaphragm MaterialKapton / Polyimide
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)150 Watts
Impedance4Ω
