  • PRV Audio TW150SD-4 Super Tweeter Pair 4 Ohm
PRV AudioPart # 294-3442
Model: TW150SD-4
Measuring at an encompassing diameter of 2.37", and demanding a cutout mounting hole of 1.93", the PRV TW150SD-4 4 Ohm tweeters serve as an excellent drop-in enhancement for vehicles equipped with standard 2" factory tweeters. They also offer the potential to revolutionize your sound system with minimal adjustments, thanks to the straightforward flush-mount screw-on ring installation.
  • 32 mm dome with 1.1″ voice coil – 4 Ohm
  • High-Strength neodymium magnet within compact machined housing
  • Non-fatigue cloth diaphragm, for extended frequency response
  • Ultra-high sensitivity of 94dB to deliver high output.
Your Price: $49.91
Save $12.48 (20%)
We'll send you an email when PRV Audio TW150SD-4 Super Tweeter Pair 4 Ohm is back in stock or available for preorder.
Introducing the revolutionary TW150SD-4, poised to redefine the silk dome tweeter market (oftentimes referred to as a soft dome). This pioneering design boasts a spacious 32mm dome accompanied by a substantial 1.1” voice coil, capably handling up to 120 Watts of power. Imbued with outstanding clarity and remarkable response above 2Khz, this innovation sets a new standard.
Championed for high-end car audio and motorcycle systems, the TW150SD-4 tweeters are meticulously crafted for versatile mounting, courtesy of their shallow profile that effortlessly accommodates tight spaces.
Empowered by high-strength neodymium magnets, these tweeters act as a dynamic powerhouse, ensuring heightened efficiency without compromising on size.
Moreover, these neodymium tweeters are meticulously designed to harmonize seamlessly with high-efficiency loudspeakers, bestowing your system with premium, high sound output. The integrated inline capacitor expertly smoothens lower frequencies, paving the way for a pristine delivery of exquisite high frequencies laden with intricate detail.
BrandPRV Audio
ModelTW150SD-4
Part Number294-3442
UPC810075522723
Unit of MeasurePairs
Weight0.65
Tweeter TypeSoft Dome
Power Handling (RMS)120 Watts
