  • PRV Audio RS65-PRO RS Series 6.5” Full Range Car Speaker Pair 4 Ohm
PRV AudioPart # 294-3586
Model: RS65-PRO
The PRV Audio RS65-PRO is a 6.5" full-range car speaker pair made to upgrade factory sound systems. It offers higher clarity, better dynamic range, and stronger output than standard OEM speakers while fitting easily into most door speaker locations.
  • High efficiency design plays loud and clear even on modest power
  • Wide frequency range (60-18,000 Hz) ensures both low mids and high notes are reproduced clearly
  • Shallow 2.44" depth makes installation possible in tight spaces
  • Rugged stamped steel frame withstands daily vibration and stress
  • Pro-inspired sound character for dynamic, impactful listening
Your Price: $59.91
Save $14.98 (20%)
We'll send you an email when PRV Audio RS65-PRO RS Series 6.5” Full Range Car Speaker Pair 4 Ohm is back in stock or available for preorder.
Introducing the RS65-PRO premium 6.5” OEM replacement car speakers. Designed for high performance, they are an ideal option for audiophiles upgrading any car audio system with a 2-way setup using speakers and tweeters.
The RS Series includes new subwoofers, amplifiers, and car speakers that provide high-fidelity sound and strong performance for daily use, created specifically for the car audio market.
  • With high sensitivity and a wide frequency range, these are the ideal OEM replacement speakers, easily powered by either stock or aftermarket radios
  • Compact Profile, built with a standard frame size for simple installation in many OEM door speaker locations, 4 Ohm impedance
  • Fullrange Speaker, capable of covering 60 Hz to 18,000 Hz, delivering both low midbass impact and clear high notes for detailed sound
  • These 6.5″ full range speakers feature a high quality ultra lightweight cone, producing more precise audio at 94 dB sensitivity, outperforming most factory car speakers
RS65-PRO is built for straightforward installation with a standard 6.5″ frame size that matches many OEM door speaker locations.
While made to be powered by an amplifier, this speaker can also be run from a factory or aftermarket radio, giving you clearer, higher quality sound than OEM speakers.
The RS65-PRO surrounds you with music throughout your vehicle as a direct replacement for your existing speaker. Upgrade today and experience the difference!
This speaker is a strong upgrade for those who want more than a basic factory component set. With a frequency range of 60 Hz to 18,000 Hz, it covers a broad spectrum, letting you transform your system with just a speaker upgrade alongside your stock tweeter.
Its standout feature is the shallow 2.44-inch mounting depth and compact profile, making it perfect for tight spaces where standard speakers cannot fit.
With a sensitivity of 94 dB, the RS65-PRO is highly efficient at turning low power into sound, all while maintaining its slim design.
Built to perform and able to handle 100 Watts RMS each, these car speakers are the most ideal OEM replacement in a 3-Way or 2-Way component setup.
The RS65-PRO speakers do not require a large amount of power to operate. They get loud extremely easy with less than 200 watts RMS per pair making it suitable for use with the compact QS400.4 2 Ohm, installing 4 Speakers, one per Channel.
  • Nominal Diameter: 6.5″ (152 mm)
  • Nominal impedance: 4 Ohm
  • Continuous Program Power (RMS)**: 100 Watts
  • Max Peak Power***: 200 Watts
  • Sensitivity 2.00V at 1m: 94 dB
  • Frequency Response: 60 – 18,000 Hz
  • Voice Coil Diameter: 1.0″ (25.4 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Winding Depth: 9.20 mm
  • Former Material: Kapton
  • Magnetic Gap Depth: 5.0 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 6.57” (167 mm)
  • Front Mount Baffle Cutout: 5.75″ (146 mm)
  • Mounting Depth: 2.44” (62 mm)
  • Overall Depth: 2.76” (70 mm)
  • Net Weight: 2.70 lbs. (1.25 kg)
**Continuous Program Power (RMS) is the maximum power that the speaker can handle considering a regular musical program using our recommended filters, this power can be used to define the optimum amplifier power to avoid a clean signal without clipping or saturation.
BrandPRV Audio
ModelRS65-PRO
Part Number294-3586
UPC810075527261
Unit of MeasurePairs
Weight7.05
Speaker Size6"
Speaker TypeMidrange / Midbass
Power Handling (RMS)100 Watts
