  • PRV Audio RPD3220Ph Phenolic Replacement Diaphragm for D3220Ph Midrange Compression Driver
PRV AudioPart # 294-2854
Model: RPD3220Ph
The RPD3220Ph phenolic field replaceable diaphragm from PRV Audio will have your D3220Ph midrange compression driver operational in no time flat!
Your Price: $39.91
Save $9.98 (20%)
We'll send you an email when PRV Audio RPD3220Ph Phenolic Replacement Diaphragm for D3220Ph Midrange Compression Driver is back in stock or available for preorder.
PRV Audio's RPD3220Ph is the phenolic replacement diaphragm for the PRV Audio D3220Ph midrange compression driver. The Kapton® former and 3" diameter copper voice coil increase power handling, even when used down to 600 Hz with a 600 Hz, 12 dB/octave crossover.
BrandPRV Audio
ModelRPD3220Ph
Part Number294-2854
UPC799928734165
Weight0.15
