  • PRV Audio EX4.6 PRO Car Audio 4-way Electronic Crossover
PRV AudioPart # 294-3048
Model: EX4.6 PRO
Bringing innovation and technology to the automotive sound market, PRV Audio's EX4.6 PRO electronic crossover, makes it easy to customize your sound with a wide variety of frequency and filter adjustments. Featuring 4-way adjustable high and low pass filters and also output level control on each channel, plus an adjustable bass boost option on the Sub Out channel. The EX4.6 PRO is ideal for perfecting your audio system.
  • Up to 9 volt RMS output for excellent noise rejection and a low noise floor
  • 2, 3, or 4 channel inputs makes this crossover suitable for almost any installation
  • Up to 12 dB of bass boost at 45 Hz to set up your system for maximum impact
  • On/off button for each output to easily isolate channels for easy setup
  • Accepts up to 4 volt input for use with high output head units
Dayton Audio AXIS-8 DSP with Sub Effects
Price: $349.98Part # 230-501
See all items in Car Crossovers & Equalizers
Your Price: $64.91
Save $16.23 (20%)
We'll send you an email when PRV Audio EX4.6 PRO Car Audio 4-way Electronic Crossover is back in stock or available for preorder.
Order in the next 3 hr 50 min to ship today. Details
PRV Audio's EX4.6 PRO electronic crossover gives you tons of flexibility to make it easy to tune your car audio system for optimum sound. With 4-way adjustable high and low pass filters and also output level control on each channel this crossover gives you a wide variety of adjustments for most situations. To get maximum power and impact from your system the EX4.6 PRO also includes an 0-12 dB bass boost at 45 Hz on the subwoofer output
The EX4.6 PRO uses a unique 2 or 4 channel input (1 stereo and 2 mono inputs) with 6 channel output setup (2 stereo and 2 mono outputs) to give you many options when designing your system. If using just the 2 channel stereo input you have the ability to rout the signals to all 6 outputs to run stereo midranges and tweeters with mono subwoofer and midbass. This feature ensures that all the capability of this crossover can be utilized even with the simplest of sources.
With up to 9 volts RMS of output on each channel, the EX4.6 PRO will help to keep your system quiet and even give you plenty of power to split the outputs for running multiple amplifiers. Induced noise in an audio system is generally very low voltage, so the high output voltage capability creates a greater differential between noise and the actual audio signal. This this means that you can set your amplifier gains lower to amplify less unwanted noise with no loss in overall output capability. Also, when running multiple subwoofer amplifiers this extreme output capability means that you can split the signal and still have enough headroom to push each amplifier to their limit.
• High out channels: High pass - adjustable 400 to 10,000 Hz (12 dB/octave)
• Mid high out channels: High pass - adjustable 150 to 5,000 Hz (12 dB/octave)
Low pass - adjustable 700 to 15,000 Hz (12 dB/octave)
• Mid low out channel: High pass - adjustable 25 to 4,000 Hz (12 dB/octave)
Low pass - adjustable 300 to 5,000 Hz (12 dB/octave)
• Sub out channel: Low pass - adjustable 55 to 300 Hz (12 dB/octave)
Bass boost - adjustable 0 to +12 dB@ 45 Hz
• Max output voltage: 9V RMS
• Max input voltave: 4V RMS
• Signal to Noise: >90 dB
• Input impedance: 10K ohms
• Distortion: 0.02% THD
• Channel seperation: >80 dB
• Frequency response: 20 to 20,000 Hz
• Supply voltage: 10V - 16V DC
• Current consumption: 200 mA
• Output impedance: 470 ohms
• Dimensions: 1.3" H x 9" W x 6.3" D
• Weight: 1.45 lbs.
BrandPRV Audio
ModelEX4.6 PRO
Part Number294-3048
UPC602938022620
Weight1.55
