  • PRV Audio EQ7-15 7 Band Graphic Equalizer
PRV AudioPart # 294-3424
Model: EQ7-15
Designed with precision by PRV, the EQ7-15 equalizer empowers car audio enthusiasts to achieve unparalleled mastery over their custom and competition sound systems, ensuring the utmost quality in sound amplification. Featuring seven bands of equalization, this advanced tool grants you the ability to meticulously fine-tune your audio, enabling you to sculpt and refine your music to achieve a state of sonic perfection.
  • 1/2 – DIN Graphic Equalizer with 2 Selectable inputs
  • 7- Band Graphic Equalizer: 50Hz, 125Hz, 320Hz, 750Hz, 2,200Hz, 6,000Hz, 16,000Hz
  • 6-Channel / 15-Volt RCA Line-Level Output ( Front, Rear and Subwoofer)
  • Front Panel Selectable illumination: White or Orange LED
  • Subwoofer level control with a Selectable 12dB Low-Pass Filter (60Hz or 120Hz)
  • Fader Control (Right/ Left)
Dayton Audio AXIS-8 Digital Signal Processor with Sub Effects
Price: $349.98Part # 230-501
See all items in Car Crossovers & Equalizers
Your Price: $74.91
Save $18.73 (20%)
We'll send you an email when PRV Audio EQ7-15 7 Band Graphic Equalizer is back in stock or available for preorder.
Order in the next 3 hr 0 min to ship today. Details
Diverging from conventional EQ designs, The EQ7-15 places a distinct emphasis on generating the powerful signal required to unleash the full potential of your custom sound system. Crafted using some of the finest and most dependable electrical components, including many with 1% tolerance, the EQ7-15 ensures unwavering precision.
Married with a remarkable 20dB headroom capability and 15 volts outputs, this audio equalizer boasts unmatched signal performance, ensuring your amplifiers receive a pristine, potent signal for unparalleled performance. The EQ7-15 boasts a straightforward graphic equalizer setup, featuring a dedicated control knob for each frequency band. These knobs empower you to either attenuate or boost specific frequencies within your mix.
All 7 knobs are ergonomically designed for optimal grip, featuring precision stop points at 0 dB gain. Each adjustment provides a range of -12dB to +12dB on every frequency point, accompanied by a generous 20dB headroom. This unique capability allows for amplification of the signal with high peak levels, free from any signal compression or distortion.
To enhance your PRV EQ7-15 Equalizer experience, consider integrating a Crossover or Digital Signal Processor to ensure precise frequency range tuning for each component within your custom system. With the PRV Radio Box, you can easily control multiple EQ7-15 units, placing system mastery at your fingertips alongside your Single Din Radio.
BrandPRV Audio
ModelEQ7-15
Part Number294-3424
UPC810075521344
Weight1.6
