  • PRV Audio D4500Ph-Nd 2" Neodymium Phenolic Compression Driver
CLEARANCE PRV Audio D4500Ph-Nd 2" Neodymium Phenolic Compression Driver
PRV AudioPart # 294-3548
Model: D4500Ph-Nd
The PRV Audio D4500Ph-Nd 2" Neodymium Phenolic Compression Driver is expertly engineered to deliver high-fidelity sound with exceptional efficiency and clarity. Featuring a neodymium magnet and a phenolic diaphragm, this compression driver offers superior performance, making it an ideal choice for professional audio systems and high-end speaker setups. Its lightweight yet powerful design ensures maximum output with minimal distortion, providing a premium audio experience.
  • 2-inch compression driver with neodymium magnet for enhanced performance
  • Phenolic diaphragm for superior sound clarity and durability
  • Handles up to 200 watts of continuous power
  • Ideal for professional audio systems and high-end speaker setups
  • Lightweight design for easy installation and maximum efficiency
We'll send you an email when PRV Audio D4500Ph-Nd 2" Neodymium Phenolic Compression Driver is back in stock or available for preorder.
The PRV Audio D4500Ph-Nd stands out with its 2-inch phenolic diaphragm, designed to produce clear and precise sound across a wide frequency range. The neodymium magnet provides a powerful magnetic field, ensuring high efficiency and excellent transient response. This combination results in a compression driver that delivers crisp, detailed audio, perfect for professional sound reinforcement and high-fidelity speaker systems.
This compression driver is perfect for applications where clarity and efficiency are crucial. Whether you are building a professional PA system, upgrading a high-end speaker setup, or enhancing an existing audio system, the D4500Ph-Nd offers exceptional performance. Its lightweight design allows for easy installation, while its robust construction ensures long-lasting durability, even in demanding audio environments.
Designed for reliability and superior sound quality, the PRV Audio D4500Ph-Nd 2" Neodymium Phenolic Compression Driver is a top choice for audio professionals and enthusiasts alike. Its advanced engineering and high-quality components make it a dependable and powerful addition to any audio system. Experience the difference in sound clarity and efficiency with the PRV Audio D4500Ph-Nd and elevate your audio setup to new heights.
BrandPRV Audio
ModelD4500Ph-Nd
Part Number294-3548
UPC810075522884
Weight9.59
Diaphragm MaterialPhenolic
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)500 Watts
