  • PRV Audio D2200Py 2" Phenolic Compression Driver 8 Ohm
CLEARANCE PRV Audio D2200Py 2" Phenolic Compression Driver 8 Ohm
PRV AudioPart # 294-3436
Model: D2200Py
Read 1 Review or
Introducing the D2200Py, a streamlined answer tailored for mid-high vocal reproduction, boasting remarkable sensitivity and a delightful sonic character courtesy of its polyimide diaphragm.
  • Low mass CCAW voice coil and polyimide diaphragm for natural response
  • Designed for midrange and vocals from 500 to 7,000 Hz
  • High Output – 110 dB sensitivity
  • Compact driver design for easy front mount installation
We'll send you an email when PRV Audio D2200Py 2" Phenolic Compression Driver 8 Ohm is back in stock or available for preorder.
The fusion of elevated output capability and a harmonious mid-range frequency response empowers this horn driver to seamlessly integrate into an extensive array of high-output audio scenarios, specifically tailored for vocal reinforcement: be it in PRO, Home, Car, or PROAudioOnWheels® Audio Systems.
Embraced by fervent enthusiasts of high-output mobile audio, the PRV Audio D2200Py stands as the prime choice for intense SPL car audio competitions across South America. Simultaneously, its utilization by DJs in high SPL speaker cabinets to captivate audiences numbering in the thousands underscores its unwavering ability to entertain and engage on a grand scale.
Boasting a petite driver diameter, this design facilitates straightforward front mounting, streamlining the installation process without necessitating the detachment of the driver from any WGP14-50 Horn. With a mere 5.24" diameter, the driver offers ample clearance to comfortably fit within the 5.65" baffle cut requisite for our 2" exit horns from the WGP14-50 Series.
Marrying PRV's extensive expertise with an unwavering dedication to customer satisfaction, they've engineered a compact yet incredibly potent driver, effectively addressing the critical concerns of component spacing and weight.
The polyimide diaphragm is seamlessly integrated with a 2" diameter copper-clad aluminum wire and a Kapton® former, contributing to its robust 100 watts RMS power handling rating (when used alongside the recommended 500 Hz, 12 dB/octave high pass crossover). Impressively, the D2200Py achieves an astounding 110 dB of output with just 1 watt of input power (2.83V) when gauged at a one-meter distance, rendering it well-suited even for the most acoustically demanding environments. Mounting hardware, alongside a capacitor, is included.
BrandPRV Audio
ModelD2200Py
Part Number294-3436
UPC810075520637
Weight6.75
Diaphragm MaterialKapton / Polyimide
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)100 Watts
