  • PRV Audio 8MR450A Alto Series 8" Midrange Driver 8 Ohm
PRV AudioPart # 294-2950
Model: 8MR450A
The PRV Audio 8MR450A from the Alto Series is a professional-grade 8" midrange loudspeaker engineered for high-output sound systems in car audio, pro audio, and custom installations. With a shallow 3.21" mounting depth and a 450W program power rating, it delivers powerful midrange clarity without compromising space or performance.
  • 1.5" dual-layer CCAW voice coil on glass fiber former allows high power handling
  • Copper sleeve on pole piece reduces inductance for improved high-frequency response
  • Triple roll cloth surround and fiber-pressed paper cone offer durability and clarity
  • Shallow 3.21" mounting depth facilitates installation in tight spaces
  • Frequency response of 80–9,500 Hz covers critical midrange frequencies​
Your Price: $44.91
Save $11.23 (20%)
5 In Stock
We'll send you an email when PRV Audio 8MR450A Alto Series 8" Midrange Driver 8 Ohm is back in stock or available for preorder.
Order in the next 1 hr 30 min to ship today. Details
PRV Audio 8MR450A 8" Alto Series Midrange Speaker 8 Ohm
PRV Audio’s ALTO Series is thoughtfully designed and voiced to deliver natural, smooth sound with dynamic character. A special composite cone is used to achieve superior fidelity by smoothing the frequency response and maintaining a low moving mass, which boosts efficiency.
New features on the 8MR450A give it high output capability with low distortion, making this midrange ideal for delivering critical midrange frequencies in any high-output sound system. A great addition to the Alto Series!
  • 2″ dual-layer CCAW voice coil wound on a glass fiber former
  • Low inductance delivers excellent transients and extended high frequency response up to 9,500 Hz
  • Large voice coil winding improves power handling, providing a 450 watts RMS continuous program power rating
  • High sensitivity of 96 dB makes it a strong budget option for high-output home, car, and professional audio systems
  • Full copper sleeve on the pole piece reduces distortion and inductance
The new 8MR450A from the ALTO Series offers everything you look for in a midrange pro audio loudspeaker, featuring a compact and versatile design with just 3.21” of mounting depth without sacrificing performance.
Its 38 mm (1.5 in) copper-clad aluminum wire is wound in a double layer with high-temperature resin adhesive on a durable, ventilated glass fiber former. A copper sleeve on the pole piece further reduces inductance to enhance high frequency response.
A triple roll cloth surround paired with an optimized fiber-pressed paper cone provides smooth and extended frequency response.
This professional midrange speaker is designed to handle 100 Hz to 6,000 Hz in three-way systems, but also performs well as a door speaker in car audio setups and as a woofer in two-way satellite speaker designs.
General Specifications
  • Nominal Diameter: 8″ (203 mm)
  • Nominal impedance: 8 Ohms
  • Rated AES Power Handling (RMS): 225 Watts
  • Program Power: 450 Watts
  • Max Peak Power: 900 Watts
  • Sensitivity 2.83V at 1m: 96 dB
  • Recommended Hi Pass Crossover:* 140 Hz**
    *For Full Power Handling **12db Per Octave Crossover
  • Frequency Response at -10dB: 80 – 9,500 Hz
  • Voice Coil Diameter: 1.5″ (38 mm)
  • Voice Coil Wire: Copper
  • Voice Coil Winding Depth: 11.0 mm
  • Former Material: Kapton
  • Magnetic Gap Depth: 6.0 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 8.22″ (209 mm)
  • Front Mount Baffle Cutout: 7.26″ (184.5 mm)
  • Mounting Depth: 3.21″ (81.5 mm)
  • Overall Depth: 3.50″ (89 mm)
  • Net Weight: 4.63 Lbs (2.1 kg)
BrandPRV Audio
Model8MR450A
Part Number294-2950
UPC602938022521
Weight5.2
Nominal Diameter8"
Power Handling (RMS)225 Watts
Power Handling (MAX)450 Watts
Impedance8Ω
Frequency Response80 to 9,500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)65.26Hz
DC Resistance (Re)5.8Ω
Voice Coil Inductance (Le)0.257mH
Mechanical Q (Qms)15.19
Electromagnetic Q (Qes)0.57
Total Q (Qts)0.55
Compliance Equivalent Volume (Vas)1.23ft³
Mechanical Compliance of Suspension (Cms)0.432mm/N
BL Product (BL)7.58T·m
Diaphragm Mass Inc. Airload (Mms)13.78g
Surface Area of Cone (Sd)241cm²
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter8.22"
Baffle Cutout Diameter7.26"
Depth3.21"
Sealed Volume0.63ft³
Sealed F398.4Hz
Vented Volume1ft³
Vented F369.1Hz
