  • PRV Audio 6MR400-4 BULLET 6" Midrange Speaker 4 Ohm
PRV AudioPart # 294-3137
Model: 6MR400-4 BULLET
Continuing PRV Audio's "pro audio on wheels" concept, the 6MR400-4 BULLET 6" midrange is built to deliver the same performance as a professional loudspeaker. Featuring an aluminum phase plug for improved high frequency response, this driver is able to give high levels of output from your custom door or rear deck.
  • Extremely wide frequency response from 145 to 12,500 Hz for smooth midrange output
  • 95 dB efficient and 200 watt RMS power handling for incredible output capability
  • Aluminum phase plug improved high frequency response on and off-axis
  • Powerful motor and low moving mass to provide incredible dynamics and detail
Your Price: $39.91
Save $9.98 (20%)
5 In Stock
We'll send you an email when PRV Audio 6MR400-4 BULLET 6" Midrange Speaker 4 Ohm is back in stock or available for preorder.
The 6MR400-4 BULLET 6" midrange speaker uses a "bullet" phase plug made from pure aluminum to lower inductance and act as a heat sink cooling system for the voice coil. Machined to perfection for even sound dissipation the phase plug also improves off-axis frequency response. Beyond good looks, this cone is extremely light, providing excellent damping to keep an incredibly natural yet accurate sound with incredible efficiency.
A triple roll cloth surround, combined with an optimized fiber pressed paper cone, ensure the speaker’s frequency response is smooth and extends to high range making an easy transition to a super tweeter. The suspension design of the 6MR400-4 BULLET features a single layer spider – which connects to the coil former with premium stitched lead wires. The cone is driven by a copper-clad aluminum wire voice coil providing high efficiency and excellent power handling.
This driver is constructed of high-performance characteristics and high-quality components to provide exceptional clarity, detail, and dynamic sound. You can expect outstanding sound stage quality and realistic sound reproduction for a great value. This is the new standard of value in high-performance bullet speakers.
Built to perform and able to handle 400 watts of continuous power, this midrange is the perfect option to replace those old 2-way or 3-way coaxial speakers. Engineered and designed to easily transform a stock system into one that can deliver concert levels. The 6MR400-4 BULLET is ideal for audiophiles seeking tremendous output without radical modifications.
BrandPRV Audio
Model6MR400-4 BULLET
Part Number294-3137
UPC619620087614
Weight5.1
Nominal Diameter6"
Bolt Circle Diameter6.125
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Impedance4Ω
Frequency Response145 to 12,500Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)144.1Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.136mH
Mechanical Q (Qms)11.98
Electromagnetic Q (Qes)0.64
Total Q (Qts)0.6
Compliance Equivalent Volume (Vas)0.16ft³
Mechanical Compliance of Suspension (Cms)0.154mm/N
BL Product (BL)6.37T·m
Diaphragm Mass Inc. Airload (Mms)7.94g
Maximum Linear Excursion (Xmax)3.25mm
Surface Area of Cone (Sd)143cm²
Cone MaterialTreated Paper
Voice Coil Wire MaterialCCA
Overall Outside Diameter6.59"
Baffle Cutout Diameter5.65"
Depth2.99"
Sealed Volume0.25ft³
Sealed F3190.2Hz
Vented Volume0.4ft³
Vented F3113.2Hz
