  • PRV Audio 6MR250SEAL 6" Sealed Back Midrange 8 Ohm
PRV AudioPart # 294-3526
Model: 6MR250SEAL
Elevate your audio system with the PRV Audio 6MR250SEAL, a 6-inch sealed back midrange speaker designed to deliver exceptional sound clarity and efficiency. Ideal for car audio enthusiasts and professional sound engineers, this midrange driver provides tight, punchy mid frequencies without interference, ensuring your music sounds precisely as it should.
  • 250W peak power handling for dynamic performance
  • Sealed back design eliminates rear sound wave interference
  • 8-ohm impedance for versatile system compatibility
  • Wide frequency response range of 160Hz-9kHz for detailed mids
  • High sensitivity of 94 dB for efficient sound reproduction
Your Price: $34.91
MSRP: $43.64
Save $8.73 (20%)
We'll send you an email when PRV Audio 6MR250SEAL 6" Sealed Back Midrange 8 Ohm is back in stock or available for preorder.
The PRV Audio 6MR250SEAL is engineered for superior sound performance, offering a peak power handling of 250 watts to deliver powerful and dynamic midrange frequencies. Its sealed back design prevents rear sound wave interference, ensuring that your audio remains crisp and clean without distortion. This feature makes it an excellent choice for various applications, from car audio systems to professional PA setups.
With an impedance of 8 ohms, the 6MR250SEAL is compatible with a wide range of audio systems, providing flexibility in your sound setup. It boasts a wide frequency response range of 160Hz to 9kHz, capturing the essential midrange tones that bring your music to life. Whether you're listening to vocals, guitars, or other midrange instruments, this speaker ensures they are reproduced with remarkable clarity and precision.
The 6MR250SEAL also features a high sensitivity rating of 94 dB, ensuring efficient sound reproduction even with lower power input. This efficiency translates to louder, clearer sound without straining your amplifier, making it a reliable choice for any audio enthusiast. The speaker's robust construction ensures long-lasting performance, providing you with dependable audio quality for years to come.
Upgrade your sound system with the PRV Audio 6MR250SEAL 6" Sealed Back Midrange 8 Ohm and experience the difference in sound quality and performance. Whether you're enhancing your car audio or professional sound setup, this midrange driver delivers the precision and power you need for an exceptional listening experience.
BrandPRV Audio
Model6MR250SEAL
Part Number294-3526
UPC810075525717
Weight4.2
Nominal Diameter6"
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response400 to 6,000Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)387.4Hz
DC Resistance (Re)5.5Ω
Voice Coil Inductance (Le)0.19mH
Mechanical Q (Qms)23.17
Electromagnetic Q (Qes)2.8
Total Q (Qts)2.5
Compliance Equivalent Volume (Vas)0.016ft³
Mechanical Compliance of Suspension (Cms)0.017mm/N
BL Product (BL)6.84T·m
Surface Area of Cone (Sd)139cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter6.58"
Baffle Cutout Diameter5.79"
Depth2.2"
Sealed Volume0.00275ft³
Sealed F3632.5Hz
Vented Volume0.573ft³
Vented F3249.2Hz
