  • PRV Audio 69MR500-4 BULLET 6" x 9" Midrange Speaker 4 Ohms
PRV AudioPart # 294-3133
Model: 69MR500-4 BULLET
Continuing PRV Audio's "pro audio on wheels" concept, the 69MR500-4 BULLET 6" x 9" midrange is built to deliver the same performance as a professional loudspeaker. Featuring an aluminum phase plug for improved high frequency response, this driver is able to give high levels of output from your custom door or rear deck.
  • Extremely wide frequency response from 145 to 12,500 Hz for smooth midrange output
  • 96 dB efficient and 250 watt RMS power handling for incredible output capability
  • Aluminum phase plug improved high frequency response on and off-axis
  • Powerful motor and low moving mass to provide incredible dynamics and detail
Your Price: $64.91
Save $16.23 (20%)
9 In Stock
We'll send you an email when PRV Audio 69MR500-4 BULLET 6" x 9" Midrange Speaker 4 Ohms is back in stock or available for preorder.
The 69MR500-4 BULLET 6" x 9" midrange speaker uses a "bullet" phase plug made from pure aluminum to lower inductance and act as a heat sink cooling system for the voice coil. Machined to perfection for even sound dissipation the phase plug also improves off-axis frequency response. Beyond good looks, this cone is extremely light, providing excellent damping to keep an incredibly natural yet accurate sound with incredible efficiency.
A triple roll cloth surround, combined with an optimized fiber pressed paper cone, ensure the speaker’s frequency response is smooth and extends to high range making an easy transition to a super tweeter. The suspension design of the 69MR500-4 BULLET features a single layer spider – which connects to the coil former with premium stitched lead wires. The cone is driven by a copper-clad aluminum wire voice coil providing high efficiency and excellent power handling.
This driver is constructed of high-performance characteristics and high-quality components to provide exceptional clarity, detail, and dynamic sound. You can expect outstanding sound stage quality and realistic sound reproduction for a great value. This is the new standard of value in high-performance bullet speakers.
Built to perform and able to handle 500 watts of continuous power, this midrange is the perfect option to replace those old 2-way or 3-way coaxial speakers. Engineered and designed to easily transform a stock system into one that can deliver concert levels. The 69MR500-4 BULLET is ideal for audiophiles seeking tremendous output without radical modifications.
BrandPRV Audio
Model69MR500-4 BULLET
Part Number294-3133
UPC619620087652
Weight5.15
Nominal Diameter6 x 9"
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Impedance4Ω
Frequency Response150 to 12,500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)149Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)0.13mH
Mechanical Q (Qms)16.8
Electromagnetic Q (Qes)1.2
Total Q (Qts)1.12
Compliance Equivalent Volume (Vas)0.183ft³
Mechanical Compliance of Suspension (Cms)0.08mm/N
BL Product (BL)5.86T·m
Diaphragm Mass Inc. Airload (Mms)13.11g
Maximum Linear Excursion (Xmax)3.25mm
Surface Area of Cone (Sd)216cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter6.43" x 9.29"
Baffle Cutout Diameter5.9" x 8.6"
Depth3.85"
Sealed Volume0.5ft³
Sealed F3132.3Hz
