  • PRV Audio 18SW2400 18" Subwoofer 8 Ohm
PRV AudioPart # 294-3420
Model: 18SW2400
With its extended low-end response, great performance is realized in vented boxes as small as 7 cu. ft. This makes it ideal for applications where space is limited but powerful, deep bass is needed.
  • High BL motor for impressive control and massive output
  • Over 12.5 mm of Xmax for deep bass reproduction
  • Rigid cast aluminum frame can withstand the use and abuse of pro and car audio
  • 31 mm Height, 4″ voice coil handles 2400 watts Program RMS
Your Price: $279.91
Save $69.98 (20%)
We'll send you an email when PRV Audio 18SW2400 18" Subwoofer 8 Ohm is back in stock or available for preorder.
Estimated back in stock 9/22/2026
Incorporating a sturdy cast aluminum frame, meticulously designed with slim spokes to curtail reflections directed back at the cone, the structure also integrates strategic force cooling system openings to facilitate optimal airflow for cooling the voice coil.
Driving the voice coil is a substantial ferrite magnet featuring precisely machined top and bottom plates. Further enhancing performance, the coil benefits from an additional dual forced vent within the back plate, contributing to its capability to handle up to 2400 watts RMS seamlessly.
The driver showcases a distinctive paper cone composition, boasting remarkable high-strength pulp, meticulously engineered to ensure optimal linearity across the mid-frequency range. This is complemented by a specialized cone treatment that enhances the dampening properties of the moving assembly, thereby significantly refining the overall smoothness of its frequency response.
The voice coil, meticulously wound around a 4" glass fiber utilizing copper wire, maintains minimal weight for exceptionally rapid transient response. Engineered with a generous 31 mm winding depth, this inside/outside voice coil configuration guarantees robust thermal resilience and mechanical durability.
BrandPRV Audio
Model18SW2400
Part Number294-3420
UPC810075522945
Weight31.65
Nominal Diameter18"
Power Handling (RMS)1200 Watts
Power Handling (MAX)2400 Watts
Frequency Response45 to 2,200Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)36.3Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)1.54mH
Mechanical Q (Qms)15.57
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.56
Compliance Equivalent Volume (Vas)6.8ft³
Mechanical Compliance of Suspension (Cms)0.083mm/N
BL Product (BL)22.5T·m
Diaphragm Mass Inc. Airload (Mms)231.2g
Maximum Linear Excursion (Xmax)12.5mm
Surface Area of Cone (Sd)1290cm²
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter18.38"
Baffle Cutout Diameter16.65"
Depth8.23"
Sealed Volume4.48ft³
Sealed F356Hz
Vented Volume13.1ft³
Vented F327.3Hz
