  • PRV Audio 10FR300PR 10" Professional Full-Range Speaker 8 Ohm
PRV AudioPart # 294-2888
Model: 10FR300
The PRV Audio FR Series sets a new standard of value in high-performance full-range drivers. The 10FR300PR 10" full-range driver is an excellent choice when space is at an absolute minimum, eliminating the need for a tweeter.
  • Dual cone design allows true full-range output from a 10" driver
  • Copper shorting in motor assembly lower inductance and distortion
  • Extremely efficient (100 dB) for high output without a lot of power
  • Perfect for ultra-compact portable systems
Your Price: $79.91
Save $19.98 (20%)
16 In Stock
We'll send you an email when PRV Audio 10FR300PR 10" Professional Full-Range Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 7 hr 29 min to ship today. Details
PRV Audio's 10FR300PR 10" full-range uses a dual cone design to enable it to provide extended high frequency response while still delivering powerful low frequency output. The primary cone handles low to midrange frequencies, while the smaller secondary cone increases high frequency response from 3,000Hz to 10,000Hz. The combination of a low-distortion motor system with a copper ring and a unique woven-cloth dust cap provides exceptional clarity, detail, and dynamics with an impressive 100 dB of sensitivity.
BrandPRV Audio
Model10FR300
Part Number294-2888
UPC602938021623
Weight8.25
Nominal Diameter10"
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Impedance8Ω
Frequency Response60 to 14,000Hz
Sensitivity100dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)60.12Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.27mH
Mechanical Q (Qms)15.57
Electromagnetic Q (Qes)0.68
Total Q (Qts)0.65
Compliance Equivalent Volume (Vas)1.67ft³
Mechanical Compliance of Suspension (Cms)0.216mm/N
BL Product (BL)9.78T·m
Diaphragm Mass Inc. Airload (Mms)32.1g
Surface Area of Cone (Sd)394cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter10.10"
Baffle Cutout Diameter9.25"
Depth4.51"
Sealed Volume1ft³
Sealed F380.9Hz
Vented Volume1.25ft³
Vented F363.1Hz
