  • PKCELL Flat Top 18650 3.7V 3000mAh Rechargeable Li-Ion Battery
CLEARANCE PKCELL Flat Top 18650 3.7V 3000mAh Rechargeable Li-Ion Battery
PKCELLPart # 142-205
Model: 18650
Always have a spare charged backup battery waiting, or start a new project with this extra current 18650 Li-Ion battery for your flashlight or other electronic devices.
  • Long lasting standby charge
  • Standard size 18650 Li-Ion battery
  • 3000mAh for current hungry devices
We'll send you an email when PKCELL Flat Top 18650 3.7V 3000mAh Rechargeable Li-Ion Battery is back in stock or available for preorder.
A growing number of electronic devices use 18650 Li-Ion batteries. Flashlights are using the 18650 battery to power the current hungry LED bulbs, and to provide longer standby time when not in use. Previous rechargeable battery flashlights had to be left on the charger almost all the time so that it would be ready to use in a moment's notice. This 18650 Li-Ion battery can be left off the charger for months and still have over 90% of its charge. This enables you to charge an extra battery and have it ready to use in your flashlight in case you are going to be away from electricity for a long period of time or you forget to charge your original battery.
The 18650 3000mAh Li-Ion battery has the ability to power Dayton Audio Bluetooth amp boards when you combine them with a special Dayton Audio charging board. The KAB-BE holds three 18650 batteries and delivers longer playing time and standby time when using it with your KAB Bluetooth amp boards.
Note: Do not throw the battery into the fire. Do not solder directly to the battery. Do not store the battery in heavy static electricity areas. Do not mix the battery with different brands, chemicals, or amperage ratings. Wash your skin or clothing immediately if the battery leaks onto them. If any chemicals get into your eyes do not rub them, but wash your eyes with clean water and call a doctor. Keep out of reach of young children to avoid swallowing.
Specifications: • Voltage: 3.7 DC • Current rating: 3000mAh • Charging environment temperature range: 32° to 113° F • In use temperature range: -4° to 140° F • Size: 0.73" Dia. x 2.56" H.
BrandPKCELL
Model18650
Part Number142-205
UPC848864051604
Weight0.1
Size18650
TechnologyLi-Ion
Voltage3.7V
