  • PC Board M3 Standoff Kit with 4 pcs 16mm and 4 pcs 10mm Stud / 4 pcs Phillips Screws
Parts ExpressPart # 320-3291
This standoff kit is perfect for stacking multiple PC boards that are the same size, like the KAB-250 amp board on top of the KAB-BE battery board or KABD-250 to the LBB-3Sv2 battery board. They also help secure PC boards inside project boxes.
  • Saves space by stacking same size PC boards
  • Supports PC boards inside metal or plastic enclosures
  • Standoffs have the same M3 thread as the KAB-AB and LBB-AB mounting bracket for quick installation
Your Price: $3.98
Save $1.01 (20%)
We'll send you an email when PC Board M3 Standoff Kit with 4 pcs 16mm and 4 pcs 10mm Stud / 4 pcs Phillips Screws is back in stock or available for preorder.
Stack multiple PC boards together or secure a single one with this 12-piece PC board standoff kit. Stacking PC boards enables you to use a smaller project box to install your project in. These standoffs will secure a single PC board, or a stack, if you use it with KAB-AB or LBB-AB mounting bracket. They both use the same M3 thread.
Specifications: • Stud total dimensions with thread: Four 16 mm L x 4.6 mm Dia., four 10 mm L x 4.6 mm Dia. • Screw length: Four 6.8 mm • Thread size on studs and screws: M3.
Part Number320-3291
UPC848864076980
