Outdoor Amplified HDTV Antenna with 360 Degree Rotor & RemoteStop paying large satellite and cable bills for live over-the-air HDTV. Mount this antenna outside above the roof or in the attic to pick up over-the-air broadcast up to 60 miles away. If you live between two major cities you should be able to pick up over 30 channels, since this antenna has a built-in rotor. Without a rotor most antennas pick up only in one direction, or you have to buy a separate rotor and rotor wire. Since this antenna has a built-in rotor there's no need to run a separate rotor wire. The power for the motor runs through the coax antenna cable. There're also two TV outputs on the rotor box to run two HDTV tuners at the same time. The included wireless remote enables you to rotate the antenna from your easy chair. Mounts with up to 1-1/8" mast sold separately.
TV signal reception is affected by multiple factors such as antenna height, terrain, distance from the broadcasting transmission antenna, and output power of the transmitter. Maximum reception range of for this antenna is 60 miles but the actual range may vary depending on conditions. Since this antenna's design is UHF, which most broadcast stations use now, it holds the signal better than combination VHF/UHF antennas.
Note: The cable from the rotor box goes to the TV and the antenna plugs into the center coax connector. The outer connector goes to another TV if desired.
Specifications: • Frequency range: 470~810 MHz UHF • Max signal gain: 28 dB • Impedance: 75 ohm • Power supply voltage output: 12 VAC @ 400 mA • Dimensions including rotor: 16" L x 16" H x 10.5" W • Rotor box dimensions: 5.25" W x 1.5" H x 3.25" D without coax terminals.
Kit Contents:
• HDTV Yagi antenna
• Motor fixed bolster
• Rotor control box
• Remote for rotor control box
• 32 ft. black coax cable
• Power supply for rotor control box
