  • Onkyo DX-C390 6-Disc CD Player
OnkyoPart # 252-559
Model: DX-C390
The Onkyo DX‑C390 is a high-fidelity, 6-disc carousel CD changer that blends expert-level sound technology with uninterrupted playback convenience. It delivers smooth, low-noise audio through advanced circuitry and robust digital signal protection for a refined listening experience.
  • 6-disc carousel lets music play continuously while you add or change discs effortlessly
  • Vector Quantizer Audio and 128× oversampling produce highly accurate, detailed sound
  • VLSC circuitry smooths digital pulses into cleaner analog waveforms for clearer playback
  • Direct Digital Path isolates the audio signal using shielded wiring to minimize noise interference
  • Supports CD, CD‑R/RW, and MP3 discs with 40-track programming and multiple repeat modes
  • Dual digital (optical and coaxial) plus analog outputs offer flexible playback and conversion options
  • Quartz-based AccuPulse system guarantees reliable signal tracking and accurate performance
Your Price: $299.99
Save $75.00 (20%)
We'll send you an email when Onkyo DX-C390 6-Disc CD Player is back in stock or available for preorder.
Order in the next 1 hr 55 min to ship today. Details
The Ultimate CD Playback
This audiophile-grade component offers the best of both worlds: precision performance and everyday convenience. For those seeking the ultimate sound quality, it features a high-precision multi-bit D/A converter and 128x oversampling for exceptional detail and clarity. For those who value flexibility, the 6-disc changer provides six repeat modes, 40-track programming, and the ability to swap out up to five discs while the sixth continues playing, ensuring uninterrupted music enjoyment.
Hours of Uninterrupted Music
The DX-C390 offers the convenience of a 6-disc changer with six repeat modes and 40-track programming, so you can enjoy uninterrupted playback. You can even swap out up to five discs while the sixth continues playing, keeping the music going without interruption. Housed in a durable chassis with a brushed aluminum front panel, this player is built to deliver hours of continuous music for the soundtrack of your life.
Marvel at Crystal-Clear Playback
The DX-C390 incorporates our exclusive VLSC (Vector Linear Shaping Circuitry), delivering a smoother and more refined audio signal. Equally important for pure sonic enjoyment is the Direct Digital Path, a shielded, high-quality cable that protects delicate audio signals from noise generated by nearby circuits. With its durable chassis and brushed aluminum front panel, the DX-C390 is built to provide hours of uninterrupted music, serving as the perfect soundtrack to your life.
Features
  • 6-Disc carousel changer with ultra-quiet loading mechanism
  • VLSC (Vector Linear Shaping Circuitry)
  • VQA (Vector Quantizer Audio) technology
  • CD-R/CD-RW/MP3 CD playback capability
  • Multi-bit DAC Texas Instrument – 32 bits / 384 kHz
  • 128 x oversampling
  • Change up to 5 discs during play
  • Optical & coaxial digital output
  • Fixed output
  • 40-track programming
  • 6 Repeat modes (Entire disc/All discs/Random tracks/ Programmed tracks/Random memory/Single track)
  • 4-mode display dimmer
  • Green light for disc recognition
  • Brushed aluminum front panel
  • Full-function RI remote control
  • Signal Readout System: Optical Non-Contact
  • Reading Rotation: About 500-200 r.p.m (Constant linear velocity)
  • Linear Velocity: 1.2-1.4 m/s
  • Error Correction System: Cross Interleave Reed Solomon Code
  • DAC Converter: Multi-bit
  • Number Of Channels: 2 (Stereo)
  • Digital Filter: 128 x oversampling
  • Frequency Response: 5 Hz-20 kHz
  • Total Harmonic Distortion: 0.004% (at 1 kHz)
  • Dynamic Range: 98 dB
  • Signal To Noise Ratio: 107 dB
  • Wow And Flutter: Below threshold of measurability
  • Power Supply: AC 120 V, 60 Hz
  • Power Consumption: 10 W (120V, 60 Hz)
  • Stand-by Power Consumption: 3.9 W
  • Dimensions (W X H X D): 17.13" x 5.16" x 17.01" (435 x 131 x 432 mm)
  • Weight: 15 lbs. (6.8 kg)
BrandOnkyo
ModelDX-C390
Part Number252-559
UPC751398005435
Weight18.55
