  • OPEN BOX B&C 18DS115 18" Professional Neodymium Subwoofer 8 Ohm
CLEARANCE OPEN BOX B&C 18DS115 18" Professional Neodymium Subwoofer 8 Ohm
1 Question, 1 Answer or
B&C Speakers
Part #86-294-6026
B&C Speakers
Part #86-294-6026
Model: 18DS115
What is Open Box?
Open Box Guarantee
No Risk, No Hassle
View It New
B&C designed the 18DS115 18" high output subwoofer to produce more output and lower distortion than any other comparably priced driver. With high excursion, incredible efficiency, and excellent power handling, this driver has true earth shaking output capability.
  • 98 dB efficiency to ensure high output even with modest amplification
  • Double silicone spider keeps excursion linear even beyond rated Xmax
  • Neodymium magnet allows a very high force factor without excess weight
  • 4.5" four layer CCA voice coil allows high power handling and Bl
  • Aluminum shorting ring help control the voice coil for lower distortion
CLEARANCE $585.00
MSRP: $879.32
Save $294.32 (33%)
Order in the next 0 hr 58 min to ship today. Details
2In Stock
B&C's 18DS115 18" subwoofer is the next evolution in high output subwoofer design. Using a new, longer, four layer aluminum voice coil to produce more energy in the gap, higher sensitivity, lower distortion, and better overall performance. The 18DS115 features a 40 mm long, 4.5" diameter (116mm) copper clad aluminum wire voice coil. With a 1,700watt AES power rating, 98 dB sensitivity, and over 16.5 mm of linear excursion, this high energy subwoofer is a significant step forward from similar models in the B&C range, even approaching the performance of their 6" voice coil alternatives.
BrandB&C Speakers
Model18DS115
Part Number86-294-6026
Weight31.5
