  • OPEN BOX Atlas Sound APF-15T 15 Watt Loudspeaker with Transformer
CLEARANCE OPEN BOX Atlas Sound APF-15T 15 Watt Loudspeaker with Transformer
AtlasIED
Part #86-242-9341
AtlasIED
Part #86-242-9341
Model: APF-15T
What is Open Box?
Open Box Guarantee
No Risk, No Hassle
View It New
Provide 15 watts of continuous power handling with superior intelligibility and efficiency with Atlas Sound APF Series Omni-Purpose® loudspeakers.
  • Choose from matching grilles, enclosures and mounting. Rings (order separately)
  • Double re-entrant design provides superior audibility of voice and tone signaling
  • High-efficiency, 15 watt compression driver with proven record of outstanding service reliability
  • May be flange or recess mounted
  • Transformer(T) equipped version for 25, 70.7, or 100V line
  • Vandal and environment-resistant metal construction for outdoor or indoor use
CLEARANCE $83.00
MSRP: $122.99
Save $39.99 (33%)
Order in the next 0 hr 17 min to ship today. Details
1In Stock
Provide 15 watts of continuous power handling with superior intelligibility and efficiency with Atlas Sound APF Series Omni-Purpose® loudspeakers. Vandal-resistant units are designed for flange or recessed mounting to panels, interior/exterior walls, or ceilings. Loudspeakers are finished in gray baked epoxy. Metal construction withstands adverse temperatures, humidity and physical abuse. For flexibility and optimum adjustment convenience, transformer-equipped Model APF-15T includes the Vari-Tap® Control/connect center with 7 position, wattage/impedance selection switch.
Weather-resistant metal construction and enclosed wiring terminals eliminate the need and cost of a backbox. However, for aesthetic consideration and retrofit convenience, models will flange mount to any standard size ceiling or wall baffle and/or enclosure capable of accommodating conventional 6" or 8" diameter loudspeakers. Model FAMT-6 mounting kit is required for 8" models. Recessed installation may be accomplished by mounting Models APF-15 or APF-15T into a 4" or 5 1/2" deep opening, respectively, or to an L20 Series enclosure. L20 Series also includes mounting rings and baffles.
Specifications: • Depth: 5-3/16" (13.18 cm) • Diameter: 5-5/8" (14.29 cm) • Shipping weight: 4.00 lbs (1.81 kg) • Frequency response: 600-14,000 Hz • Power taps: 1, 2, 3.8, 7.5, 15W @ 70.7V • Dispersion: 95° • Power rating: 15 watts • Sensitivity: 104 dB • UL listed/standard: 1480.
BrandAtlasIED
ModelAPF-15T
Part Number86-242-9341
Weight3.5
