  • Noble 200K Ohm Slide Potentiometer 2-1/2" Slide with Center Detent
BUYOUT Noble 200K Ohm Slide Potentiometer 2-1/2" Slide with Center Detent
Factory BuyoutsPart # 029-114
Noble 200K ohm slide pot is perfect for restoring vintage audio products. Its center detent makes it unique verses other slide pots.
  • Has center detent for use in equalizers
  • Durable wide medal shaft with center slit
BUYOUT $2.97
Save $9.03 (75%)
Only 8 In Stock
We'll send you an email when Noble 200K Ohm Slide Potentiometer 2-1/2" Slide with Center Detent is back in stock or available for preorder.
Order in the next 1 hr 16 min to ship today. Details
This 200K ohm vintage slide pot with center detent is ready for your next build. Create a new audio project or use it to replace damaged or defective slide pots in your vintage audio equipment. Hurry while supplies last.
Specifications: • Dimensions: 3.47” L x 0.5” W x 0.45” D without stem or terminals • Slide length: 2.5” • Terminal gaps: 2.6”, 3.24”, and 0.25” • Shaft length: 0.6” H x 0.32 W.
BrandFactory Buyouts
Part Number029-114
UPC848864031866
Electrical CharacteristicsLogarithmic / Audio Taper
ValueN/A
