  • Nine Tine Banana Plug with Dual Set Screws and Poly Carbonate Shell 2 Pair
Parts ExpressPart # 091-3602
Milled from solid brass, with a 24 karat gold plating for maximum signal transfer, these nine-tine, spring-loaded banana plugs are built with a polycarbonate shell to provide protection from unintended contact and accept up to 8 AWG wire.
  • Nine sping-loaded tines create a tighter fit with banana jacks and binding posts
  • Color coded polycarbonate shells
  • Dual hex screws for maximum cable retention
  • 24 karat gold plated contact surfaces
Your Price: $16.49
Save $9.50 (37%)
91 In Stock
We'll send you an email when Nine Tine Banana Plug with Dual Set Screws and Poly Carbonate Shell 2 Pair is back in stock or available for preorder.
These spring-loaded, nine-tine banana plug connectors are manufactured with color-coded polycarbonate shells for quick polarity identification and protection from possible short-circuiting contact.
Milled from solid brass and plated in 24 karat gold to provide a long lifetime of service free of oxidation, each connector features two hex-head screws to create a gas-free connection that holds your speaker wire firmly in place.
Spring-loaded tines create a more solid connection with 5-way binding posts and banana jacks than standard banana plugs. Accepts up to 8 AWG wire. Sold two pair per package, two red and two black, and includes a hex wrench. Dimensions: 1-7/8" L x 1/2" Dia.
When using high-strand cable, tinned leads allow for the greatest retention by the set screws.
Part Number091-3602
UPC848864019147
Weight0.108
Contact PlatingGold
Style / TypeSingle
