  • Nine Tine Banana Plug with Dual Set Screws and Carbon Fiber Shell 2 Pair
Parts ExpressPart # 091-3612
Milled from solid brass, with a 24-karat gold plating for maximum signal transfer, these spring-loaded, nine-tine banana plug connectors banana plugs feature a carbon fiber shell to provide modern styling. Accepts up to 8 AWG wire.
  • Carbon fiber wrapped brass shells for a modern appearance
  • Dual set screws for maximum cable retention
  • 24 karat gold plated contact surfaces
  • Nine tines provide more contact area than a standard banana plug
Your Price: $23.49
Save $17.50 (43%)
327 In Stock
We'll send you an email when Nine Tine Banana Plug with Dual Set Screws and Carbon Fiber Shell 2 Pair is back in stock or available for preorder.
These spring-loaded, nine-tine banana plug connectors are manufactured with a removable threaded sleeve that's wrapped in real carbon fiber for modern appeal and character. A color-coded ring offers quick polarity identification.
Milled from solid brass and plated in 24 karat gold to provide a long lifetime of service free of oxidation, each connector features two flat-head screws, beneath the removable sleeve, to create a gas-free connection between your speaker wire and the connector.
Spring-loaded tines create a more solid connection with 5-way binding posts and banana jacks than standard banana plugs. Accepts up to 8 AWG wire, and the removable tip is interchangeable with the BFA style banana plug tip used on these connectors as well as the 1/4" to 3/8" forked spade tip used on these connectors. Sold two pair per package, two with red rings and two with black rings. Dimensions: 1-7/8" L x 1/2" Dia.
Note: When using high-strand cable, tinned leads will provide the greatest retention by the set screws. Clear nylon is placed beneath the two screws to secure them during shipping. Please remove prior to use. The knurled portion of this connector is for connector insertion only, please do not try to use it to remove the carbon fiber sleeve.
Part Number091-3612
UPC848864019192
Weight0.17
Contact PlatingGold
Style / TypeSingle
