  • Nickel Plated Pin Switch w/Polycarb Plunger and Rubber Boot
CLEARANCE Nickel Plated Pin Switch w/Polycarb Plunger and Rubber Boot
Parts ExpressPart # 060-812
12 VDC 1-3/64" nickel plated pin switch with cut to length polycarbonate plunger and rubber boot. Specifications: • Pin dimensions: 8 mm dia. x 17.1 mm H • Shaft diameter: 10 mm • Accepts 1/4" female disconnect.
CLEARANCE $1.11
MSRP: $3.99
Save $2.88 (72%)
46 In Stock
We'll send you an email when Nickel Plated Pin Switch w/Polycarb Plunger and Rubber Boot is back in stock or available for preorder.
Part Number060-812
UPC844632076756
Weight0.01
