  • Neutrik NL8MDXX-V-BAG speakON 8 Pole Chassis Connector Vertical PCB Mount Black
NeutrikPart # 092-071
Model: NL8MDXX-V-BAG
Read 2 Reviews or
Patent protected, reliable, cost effective, and extremely durable, Neutrik's speakON series of professional speaker and amplifier connectors offers the "quick lock" locking system and recently redesigned inserts for the cable ends.
  • Industry standard "quick-lock" speaker connector
  • 8-pole connection
  • Robust square mounting flange
  • Black finish
Your Price: $11.17
MSRP: $11.88
Save $0.71 (6%)
55 In Stock
We'll send you an email when Neutrik NL8MDXX-V-BAG speakON 8 Pole Chassis Connector Vertical PCB Mount Black is back in stock or available for preorder.
Neutrik's speakON series of professional speaker and amplifier connectors are recognized as the industry standard. Patent protected, reliable, cost effective, and extremely durable, the speakON system offers the "quick lock" locking system. speakON panel receptacles with solder terminations also allow you to use quick disconnect type terminals (0.187" x 0.020") for ease and reliability of assembly, and the NL8MDXX-V-BAG now has a metal faceplate (in nickel or black) for rugged conditions. The contacts in this series are touch proof and designed to prevent damage from arcing if disconnected under load. Ensuring fail-safe conditions for both the equipment and the operator. speakON meets the prevailing safety standards of IEC65, IEC348, CE, CSA and are UL rated (file #E135070). Connector type: Chassis connector/panel receptacle, 8-pole, square flange style with air-tight seal. Vertical PCB mount. Housing: Black plastic with metal face in a nickel finish. Mfg. #NL8MDXX-V-BAG.
BrandNeutrik
ModelNL8MDXX-V-BAG
Part Number092-071
UPC848864031743
Weight0.1
Circuit8-Pole
GenderMale
