  • Neutrik NL2MPXX Speakon 2 Pole Panel Mount
NeutrikPart # 092-0590
Model: NL2MPXX
Patent protected, reliable, cost effective, and extremely durable, Neutrik's speakON series of professional speaker and amplifier connectors offers the "quick lock" locking system and recently redesigned inserts for the cable ends.
  • IEC 61984 certified and IEC 62368-1 compliant
  • Glass reinforced V-0 materials provide strength and reliability
  • Precision keyway ensures secure connection
  • Reliable twist lock latching mechanism
  • Metal insert reinforces the locking area
Your Price: $2.78
Save $0.32 (10%)
We'll send you an email when Neutrik NL2MPXX Speakon 2 Pole Panel Mount is back in stock or available for preorder.
Order in the next 15 hr 19 min to ship today. Details
This connector meets IEC 62368-1 device standards through its IEC 61984 component certification.
It is a 2-pole chassis connector with a black D-size flange, countersunk thru holes, and 3/16" flat tabs. It does not intermate with 4-pole cable connectors.
speakON panel mount connectors are the industry standard for loudspeaker and amplifier connections. They use a durable metal locking system that makes contact only when fully engaged. These receptacles are strong, adaptable, and simple to wire.
Note: Does not intermate with the 4-pole (NL4) cable connectors.
Technical Information
Product
  • Title: NL2MPXX
  • Gender: male
Electrical
  • Contact resistance: ≤ 2 mΩ
  • Dielectric strength: 2.8 kVac
  • Insulation resistance: >0.1 GΩ (after dampheat)
  • Rated current per contact: 24 A rms continuous (audio rating significantly higher, depending on signal)
  • Rated voltage: 250 V ac
  • Attention: speakON is NOT to be used as an AC mains or power supply connector!
Mechanical
  • Lifetime: > 5000 mating cycles \
  • Termination: 3/16" flat tabs (e.g. NLFASTON)
  • Locking device: Quick Lock
  • Chassis shape: D
  • Layout: standard hole position, thru holes
Material
  • Contact plating: Ag
  • Locking element: Stainless Steel
  • Shell: Polyamide (PA 6.6)
  • Contacts: Copper Alloy
Environmental
  • Flammability: UL94 V-0
  • Temperature range: -30 °C to +80 °C
BrandNeutrik
ModelNL2MPXX
Part Number092-0590
UPC703272072545
Circuit2-Pole
GenderMale
