  • Neutrik NF2C-B/2 Profi Professional RCA Plug Pair
NeutrikPart # 092-114
Model: NF2C-B/2
Pair of professional `Phono Plug` (`RCA`- or `CINCH`- type) - marked red and black. Including 2 x 2 strain reliefs for cable O.D. 3.0 mm to 7.3 mm.
  • Makes ground before signal contact and breaks signal before ground
  • No more disturbing noise and broken speaker cones
  • Precisely machined to our demanding quality standards
  • Neutrik unique chuck type strain relief
  • Gold plated contacts
  • Sleek barrel with soft touch surface and colored shrink sleeve
  • Improved ground solder lug for ease soldering
Your Price: $22.39
Save $5.36 (19%)
66 In Stock
We'll send you an email when Neutrik NF2C-B/2 Profi Professional RCA Plug Pair is back in stock or available for preorder.
Neutrik Profi Cable Connectors
Spring loaded ground contact: retractable element with separate wedge contacts which keeps the shell in the front position when engaged thus also providing a direct and strictly coaxial electrical connection from the socket via the shell to the cable shield. All metal design, machined brass, black coated shell. Easy assembly and soldering (large soldering area, rapid-flow plating). High grade plastic insulator with high creep resistance.
BrandNeutrik
ModelNF2C-B/2
Part Number092-114
Unit of MeasurePairs
Weight0.09
GenderMale
Mounting TypeCable Mount
