  • Neutrik NC5FBV-SW 5 Pin XLR Female Cable Connector Nickel
CLEARANCE Neutrik NC5FBV-SW 5 Pin XLR Female Cable Connector Nickel
NeutrikPart # 092-412
Model: NC5FBV-SW
The Neutrik NC5FBV-SW 5 Pin XLR Female Cable Connector is designed to meet the demanding needs of professional audio applications.
  • Nickel Housing for Durability: The sturdy nickel housing offers excellent protection against wear and tear, ensuring long-term reliability.
  • Silver-Plated Contacts: Provides superior signal conductivity and corrosion resistance, enhancing audio signal quality.
  • Secure Locking System: Features Neutrik's reliable chuck-type strain relief for secure cable retention and lasting connections.
  • Versatile Application: Perfect for professional studio, live sound, and broadcast applications, supporting 5-pin XLR connections.
  • Easy Assembly: Designed for quick and straightforward assembly, with only a few simple steps required to prepare the connector for use.
CLEARANCE $10.82
MSRP: $12.08
Save $1.26 (10%)
96 In Stock
We'll send you an email when Neutrik NC5FBV-SW 5 Pin XLR Female Cable Connector Nickel is back in stock or available for preorder.
The Neutrik NC5FBV-SW 5 Pin XLR Female Cable Connector is designed to meet the demanding needs of professional audio applications. Featuring a sleek nickel housing and silver-plated contacts, this connector provides a reliable, high-quality connection for balanced audio signals. It's the ideal choice for microphone connections, audio interfaces, and sound mixing equipment, ensuring a pristine audio experience.
Crafted with a durable nickel housing, the NC5FBV-SW is built to withstand the rigors of on-the-road use and frequent handling. This robust construction not only prolongs the connector's lifespan but also maintains its aesthetic appeal over time.
To ensure exceptional audio signal transmission, the NC5FBV-SW features silver-plated contacts. These contacts provide enhanced conductivity and resistance to tarnishing, ensuring that your audio connections deliver the highest possible sound quality without compromise.
Neutrik's trusted chuck-type strain relief system offers unparalleled cable retention, safeguarding against accidental disconnections and cable strain. This system ensures that your connections are both secure and protected, even in the most demanding situations.
The NC5FBV-SW is designed for versatility, seamlessly integrating into various professional audio environments. Whether used in studio recording sessions, live sound setups, or broadcast applications, this connector delivers reliable performance and quality.
Assembly of the NC5FBV-SW is straightforward and efficient, allowing for quick preparation and use. This ease of assembly ensures that you can focus more on your audio projects and less on the complexities of hardware setup.
BrandNeutrik
ModelNC5FBV-SW
Part Number092-412
UPC848864076553
Weight0.01
