  • Neutrik NC4MD-L-1 XLR "D" Series Panel Mount Male Nickel
NeutrikPart # 092-2440
Model: NC4MD-L-1
In "D-L-1" series, the male and female fit in the same hole cut-out and are front or rear mountable. The Neutrik NC4MD-L-1 is a universal D-size metal body XLR panel mount with 4 male pins, rear solder cup terminals, Nickel housing, and silver contacts. It is RF protected via a 3-point coaxial ground contact shell of the mated connector.
  • Sliver plated Brass contacts for better conductivity
  • Robust "D" metal shell
  • Standardized 24 mm D series front or rear panel mount
  • Four solder cup terminals for easy soldering
  • Standard male 4-pin XLR for intercom headsets and other applications
Your Price: $5.57
MSRP: $5.92
Save $0.35 (6%)
75 In Stock
We'll send you an email when Neutrik NC4MD-L-1 XLR "D" Series Panel Mount Male Nickel is back in stock or available for preorder.
Order in the next 1 hr 42 min to ship today. Details
Use this Neutrik D-size XLR male receptacle in panels or other projects that require 4-pin XLR. They fit perfectly in D sized 24 mm panel cutouts making installation a breeze. The robust nickel body and silver plated brass contacts deliver long lasting performance and high quality, secure electrical transfer.
Connector type: XLR male • Shell: Nickel • Four pins: Silver plated Brass • Current capacity: 10A • Mfg. # NC4MD-L-1
BrandNeutrik
ModelNC4MD-L-1
Part Number092-2440
UPC848864058962
Weight0.06
Conductors4-Pin
GenderMale
