  • Neutrik NC3MAV XLR 3-Pin Male PCBV Mount Connector Plastic/Gold
NeutrikPart # 092-397
Model: NC3MAV
Unlock superior audio connectivity with the Neutrik NC3MAV, a 3-pin XLR male receptacle engineered for vertical print circuit board (PCB) mounting.
  • Vertical PCB Mounting: Designed for seamless integration into audio systems with vertical PCB configuration.
  • Nickel-Plated Contacts: Ensures reliable signal transmission with long-lasting durability.
  • Compact and Robust Design: Ideal for applications requiring high-density mounting and resilience.
  • Consistent Contact Pressure: Guarantees stable electrical connection and high signal integrity.
  • Ease of Assembly: Tailored for straightforward installation, simplifying the assembly process.
  • Universal Compatibility: Adheres to industry-standard specifications for broad device compatibility.
Your Price: $1.49
MSRP: $1.58
Save $0.09 (6%)
45 In Stock
We'll send you an email when Neutrik NC3MAV XLR 3-Pin Male PCBV Mount Connector Plastic/Gold is back in stock or available for preorder.
Unlock superior audio connectivity with the Neutrik NC3MAV, a 3-pin XLR male receptacle engineered for vertical print circuit board (PCB) mounting. This high-performance connector is meticulously designed for professional audio applications, offering a seamless integration into any audio system design. Featuring reliable contact integrity and a durable construction, the NC3MAV ensures optimal signal transmission and robustness for audio professionals, ensuring a clear and consistent sound in every performance.
The NC3MAV is expertly designed for vertical mounting, ensuring a neat and efficient connection within your PCBs. This design supports a streamlined audio system setup, enhancing overall performance and reliability.
With nickel-plated contacts, the NC3MAV provides exceptional signal transmission quality, maintaining the purity and clarity of your audio. This ensures that every performance or recording delivers the sound as intended, with minimal loss or interference.
Neutrik's commitment to quality is evident in the NC3MAV's robust build, designed to withstand the rigors of professional use. Its compact design does not compromise on strength, offering a solution that lasts even in demanding environments.
Experience unwavering connection stability with the NC3MAV, featuring consistent contact pressure that ensures ongoing, reliable electrical performance. This is crucial for maintaining the integrity of your audio signals over time.
The NC3MAV is not only easy to install but also universally compatible with a wide range of audio equipment, thanks to its adherence to industry standards. This versatility and ease of assembly make it an indispensable component in any professional audio toolkit.
BrandNeutrik
ModelNC3MAV
Part Number092-397
UPC848864076430
Weight0.01
Conductors3-Pin
GenderMale
Mounting TypePCB Mount
