  • Neutrik NC3FBV2 XLR 3 Pin Female PCBV Mount Nickel
NeutrikPart # 092-387
Model: NC3FBV2
Introducing the Neutrik NC3FBV2, the definitive 3-pin XLR female receptacle crafted for audio professionals who prioritize both form and function in their setups. This vertical PCB mount connector is designed to integrate seamlessly into any professional audio application, from mixing consoles to rack panels, ensuring reliable and high-quality balanced audio connections. With its superior construction and meticulous design, the NC3FBV2 stands as a testament to Neutrik's commitment to excellence in audio connectivity, making it indispensable for studio, live, and broadcast environments.
  • Vertical PCB Mount: Optimized for precise integration into audio equipment with vertical mounting requirements.
  • Industry-Standard 3-Pin Configuration: Ensures universal compatibility with balanced audio systems.
  • Exceptional Audio Quality: Guarantees clear, noise-free signal transmission for superior sound.
  • Robust Design: Engineered for longevity and reliability in demanding professional settings.
  • Streamlined Installation: Simplifies the assembly process, saving time and reducing complexity.
Your Price: $3.29
MSRP: $3.50
Save $0.21 (6%)
241 In Stock
We'll send you an email when Neutrik NC3FBV2 XLR 3 Pin Female PCBV Mount Nickel is back in stock or available for preorder.
Elevate your audio connections to new heights with the Neutrik NC3FBV2, expertly designed for audio professionals who demand reliability and performance. This 3-pin XLR female receptacle brings unparalleled clarity and stability to your audio connections, ensuring your sound remains pristine in any scenario.
The NC3FBV2 is specifically designed for vertical PCB mounting, providing a secure and stable connection while optimizing space in your equipment. This design approach facilitates better layout and organization within your audio setup, contributing to an overall cleaner and more efficient working environment.
Adhering to the industry-standard 3-pin XLR format, the NC3FBV2 ensures seamless integration with a wide range of audio equipment. This universal compatibility is crucial for maintaining consistent and high-quality audio connections across different devices and setups.
Engineered to uphold Neutrik's stringent standards for signal integrity, the NC3FBV2 provides immaculate audio transmission, eliminating noise and interference that can detract from your sound. Experience the true essence of your audio with this top-tier connector.
The NC3FBV2 boasts a construction designed to withstand the rigors of professional audio work. From the studio to the stage, this connector is built for durability, ensuring your connections remain solid, session after session.
Neutrik has streamlined the installation process for the NC3FBV2, making it quick and easy to integrate into your existing setup. This focus on usability saves valuable time, allowing audio professionals to concentrate on what they do best – creating and delivering outstanding sound.
BrandNeutrik
ModelNC3FBV2
Part Number092-387
UPC848864076331
Weight0.01
