  • Neutrik NAC3MM-1 powerCON Cable Coupler
CLEARANCE Neutrik NAC3MM-1 powerCON Cable Coupler
NeutrikPart # 092-288
Model: NAC3MM
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. • Connector: PowerCon® coupler for linking cables, one side with NAC3MPA and the other side with NAC3MPB • Mfg. #NAC3MM
  • NAC3MPA (blue/IN) to NAC3MPB (gray/OUT) coupler
  • Rugged, robust, and virtually unbreakable
  • Developed for frequently connected/disconnected systems with operator and equipment safety in mind
Neutrik NAC3MMXX PowerCON Cable Coupler
Price: $22.50Part # 092-287
See all items in AC Power Connectors
We'll send you an email when Neutrik NAC3MM-1 powerCON Cable Coupler is back in stock or available for preorder.
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. Color coded for easy identification, PowerCon® offers power-in (blue) and power-out (gray) versions with different keying to avoid the possibility of short circuiting. The contacts are designed to prevent damage from arcing when disconnected while under load. PowerCon® meets or exceeds the demands of applications in the fields of A/V usages, test and measurement equipment, computers or industrial designs. UL recognized, SEV and VDE approved. Rated at 20A/250VAC.
Note: PowerCon® is not designed to be a "mains" connector or for speaker/amplifier applications. For speaker applications please see the Speakon® series.
BrandNeutrik
ModelNAC3MM
Part Number092-288
UPC844632005114
Weight0.1
ConfigurationNeutrik powerCON
Current Rating20A
Power Connector TypeAdapter / Coupler
