  • Morel MSW 265 Shallow Classic Series 8" Composite Paper Cone Woofer 4 Ohms
MorelPart # 297-008
Model: MSW265
The Morel MSW 265 8" woofer delivers all the quality and performance you have come to expect from Morel's Classic Series with less mounting depth. At only 2.375" deep, this driver will provide excellent sound in the shallowest installations.
  • Shallow profile Damped Polymer Cone for smooth on and off axis response
  • Huge 3" Hexatech™ aluminum voice coil delivers precise control
  • 2.375" mounting depth for use in the shallowest enclosures
  • Extensive frame, coil, and motor venting lowers compression and distortion
Your Price: $208.00
MSRP: $243.99
Save $35.99 (15%)
We'll send you an email when Morel MSW 265 Shallow Classic Series 8" Composite Paper Cone Woofer 4 Ohms is back in stock or available for preorder.
Estimated back in stock 10/24/2025
With the emphasis today on smaller speaker designs, Morel has re-engineered the Classic Series woofers to minimize depth without sacrificing their sonic characteristics. At only 2.375" deep, MSW 265 8" has been optimized for use in the smallest enclosures. With a shallow profile Damped Polymer Cone this driver will provide smooth response both on and off axis for natural, room filling response. The huge 3" Hexatech™ voice coil has extensive venting in the former, frame, and magnet to ensure high power handling and low power compression. The MSW 265 is the perfect woofer for use in extremely compact 2-way or 3-way speaker designs.
BrandMorel
ModelMSW265
Part Number297-008
UPC848864043616
Weight2.3
Nominal Diameter8"
Bolt Circle Diameter8.5
Power Handling (RMS)180 Watts
Power Handling (MAX)360 Watts
Frequency Response35 to 2,000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)30Hz
Total Q (Qts)0.44
Compliance Equivalent Volume (Vas)3.12ft³
Maximum Linear Excursion (Xmax)3.5mm
Cone MaterialPoly Composite
Voice Coil FormerAluminum
Overall Outside Diameter8.75"
Baffle Cutout Diameter7.75"
Depth2.375"
Sealed Volume0.8ft³
Sealed F357.2Hz
Vented Volume1ft³
Vented F342.4Hz
