  • Mini Portable Bluetooth Ammo Box Speaker Kit Components with Pink Box
CLEARANCE Mini Portable Bluetooth Ammo Box Speaker Kit Components with Pink Box
Parts ExpressPart # 300-7311
Model: 300-7311
Build your own lightweight Bluetooth 6.75" x 3.375" x 5.5" portable speaker with this pink ammo box kit. It includes an IR remote to adjust the tone, volume and track.
  • Includes an IR remote that works through the pink ammo box
  • 3 x 2600mAh 18650 Li-Ion batteries for long lasting run time
  • Easy to build plug and screw in wiring with no soldering required
  • Lightweight speaker kit with handle to carry with you wherever you go
  • Amp board has a USB-A port for the built-in multimedia player
  • Includes 12 VDC AC adapter to power and charge while playing if desired
  • Downloadable build instructions for guidance
An incredible battery powered Bluetooth speaker kit that makes it easy to take your music everywhere
Quickly build a portable 2 x 30W max Bluetooth 4.2 speaker with this pink mini ammo box kit. All the components conveniently fit into the included mini ammo box. All you have to do is drill a few holes. Drill two 2" holes for the speakers and then cut enough space for the speaker terminals. Drill eight tiny starter holes to mount the speakers, one 1/4" hole for power and one 9/16" hole for the power switch. All the wires plug or screw directly into the boards without any soldering. Attach the speaker wires and power switch wires with 0.205" and 0.110" quick disconnects. Screw down the speakers with the included screws and attach all the wires and you're ready to impress your friends with the big hi-fi quality sound coming from a mini ammo box. The on board Bluetooth antenna delivers up to 50 ft. of wireless range. Add a little sound damping material (sold separately) to make it sound even better.
This kit's amp board includes a 3.5 mm line input jack and a USB-A port for the built-in multimedia player. Open the ammo box and plug in the flash drive with music for continuous play without using the battery from your smartphone or other portable media player. The amp board also has a 3.5 mm line input jack. This gives you the option to drill and cut more holes in the ammo box if desired for more external access. The kit includes an IR remote to adjust the input modes, tone, volume, and track selection. The IR remote works even with the ammo box's lid shut and no holes for the IR receiver. Add hook-n-loop (sold separately) to the back of the IR remote and stick it to the back of the ammo box to keep track of it.
Note: Three important manual updates. The DC jack is 1-1/2" from the bottom instead of 9/16", and the speakers should be mounted 1-7/8" from the bottom if using the included 3/4" screws. Use the 16mm standoffs to mount the battery board to the bracket.
Included in this package:
Crank up your next mini wireless audio project with this 30W x 2 digital Bluetooth 4.2 amplifier board with IR remote. It has a built-in USB port for playing digital music and smartphone charging.
Dayton Audio's compact ND65-4 aluminum cone full-range driver demonstrates the latest advances in high-excursion design processes. When teamed up with the matching ND series passive radiators this driver can produce incredible full sound from compact enclosures.
Lithium battery power is your best option when building high power portable sound projects. This battery holder charges three 18650 Li-Ion batteries when used with a 5 to 24 VDC power supply (sold separately). Enjoy prolonged listening with this 12 VDC advanced power option.
Protect small tools, electronics, or small ammo from the elements with Grip Tools mini utility box. It also works perfect for creating a small Bluetooth speaker.
The KAB-AB L-type aluminum bracket is ready to protect and mount any Dayton Audio KAB Bluetooth amp board.
Note: Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
Model300-7311
Part Number300-7311
UPC848864068336
Weight2.94
Cabinet OptionsUnfinished/Unassembled
ColorPink
Speaker TypePortable Bluetooth
Woofer Diameter2.5"
