  • Middle Atlantic REB14 Rotating Slide-Out System Base
CLEARANCE Middle Atlantic REB14 Rotating Slide-Out System Base
Middle AtlanticPart # 262-488
Model: REB14
Middle Atlantic's rotating slide-out base systems provide easy access to the rear of home audio and video equipment including DVD players, satellite receivers, amplifiers and video game consoles. This unit extends 13".
  • Easily access your components
  • Conceals inside of TV stand
  • Supports up to 75 lbs. of equipment
CLEARANCE $375.30
MSRP: $417.00
Save $41.70 (10%)
1 In Stock
We'll send you an email when Middle Atlantic REB14 Rotating Slide-Out System Base is back in stock or available for preorder.
Middle Atlantic's rotating slide-out base systems provide easy access to the rear of home audio and video equipment including DVD players, satellite receivers, amplifiers and video game consoles. Two glide rails permanently mount into your cabinet area and connect to a base that extends 13". Once extended, the base rotates 60° for simple electronic component installation and adjustment. 75 lbs. of equipment may be stacked on the base without over stressing the glide rails. Dimensions: 2" H x 17.13" W x 15" D.
BrandMiddle Atlantic
ModelREB14
Part Number262-488
UPC656747082221
Weight11.3
