  • Middle Atlantic PD-2015R-NS 20 Outlet Multi-Mount Rack Mount 15A Power Distribution
Middle AtlanticPart # 262-4362
Model: PD-2015R-NS
Middle Atlantic proudly presents the Multi-Mount series of power distribution products, with flexible mounting options, wildly generous outlet provisions, and robust feature sets - all in single rack space units!
  • 20 total outlets - 10 front panel, 10 rear panel
  • Front panel outlets are switched
  • Mounting options galore
Your Price: $297.00
MSRP: $330.00
Save $33.00 (10%)
Out of Stock
We'll send you an email when Middle Atlantic PD-2015R-NS 20 Outlet Multi-Mount Rack Mount 15A Power Distribution is back in stock or available for preorder.
With the new Multi-Mount series of rack mount power distribution products, Middle Atlantic is breaking the mold as to what a power strip should be and do. Each model features copious quantities of outlets oriented to maximize efficiency, and flexible mounting options so you can put the outlets exactly where you need them, all in a single rack space form factor.
The PD-2015R-NS gives you 20 total outlets, 10 on the front panel, and 10 on the rear.
A great innovation in the Multi-Mount series is the variable mounting options available only from Middle Atlantic. The entire Multi-Mount series ship with multiple sets of rack ears that allow you to position the strip and the outlets in a variety of orientations in 90° increments, as well as to the front or rear of your rack, flush or recessed, all to make your job easier and maximize cable routing efficiency. The outlets themselves are arranged in such a manner as to accommodate varied types of power supplies and plugs to be used - even the strip itself can be mounted horizontally or vertically, depending on the needs of the job at hand.
As if all that weren't enough, you also get RoHS, UL, and GreenGuard certification, and a 9 ft. SignalSAFE power cord to help minimize EMI. Do yourself a favor, just try a Multi-Mount from Middle Atlantic. Once you've tried it, you will find it difficult to go back to run-of-the mill power distribution.
BrandMiddle Atlantic
ModelPD-2015R-NS
Part Number262-4362
UPC656747105319
Weight6.23
ColorBlack
Cord Length9'
Number of Outlets20
Special FeaturesRack Mountable
