  • Micro JST PH 2.0 2-Pin Power/Speaker 4.48 x 3.95mm Dual Plug with 30cm Cable for Amp Boards
CLEARANCE Micro JST PH 2.0 2-Pin Power/Speaker 4.48 x 3.95mm Dual Plug with 30cm Cable for Amp Boards
Parts ExpressPart # 320-345
Connect a battery or speakers to small amplifier boards with this JST PH 2.0 type power cable. Cut in half to get two cables and check your polarity to match the JST PH 2.0 type socket on the board.
  • Fits most JST PH 2.0 type 2-pin sockets for quick hookup
  • Economical plugs on both ends, but polarity must be verified
  • 30cm cable for flexibility
CLEARANCE $0.74
MSRP: $1.79
Save $1.05 (59%)
We'll send you an email when Micro JST PH 2.0 2-Pin Power/Speaker 4.48 x 3.95mm Dual Plug with 30cm Cable for Amp Boards is back in stock or available for preorder.
This item is no longer available
Connect a battery or speakers to small amplifier boards with this JST PH 2.0 type power cable. Cut in half to get two cables and check your polarity to match the JST PH 2.0 type socket on the board. Not all JST PH 2.0 power/battery sockets' polarity are the same. It will damage most boards if you get the positive and negative/ground switched. For speaker connections it won't hurt the board to get them switched, but it'll effect the phase of the speaker. The plug-n-play action of the locking connector makes it easier to change the battery and eliminates having to solder or screw down speaker wires. Heavy vibration or GeForce won't shake the connector loose. The total wire length is 30cm and the plug dimensions are 0.18" W x 0.25"D x 0.16" H including the polarity notch.
Note: Verify power/battery polarity before pluging into a socket on a PC board. Reverse power polarity will damage most boards.
Part Number320-345
UPC848864065748
Board TypeWiring Harness
