CLEARANCE Mean Well RSP-320-5 300W 5 Volt Power Supply with PFC for LED Signs
A reliable, fully tested power supply by Mean Well for high current amplifier boards, and other 5 VDC projects requiring less than 60A. UL recognized design.
- Built-in active power factor correction (PFC) circuit smooths out the pulsating AC current which improves output performance
- Forced air cooling by built-in DC fan with speed control function
- Built-in overload, over voltage, over temperature and short circuit protection for long life
- UL recognized and CE certified for safety
- LED indicator for power on identification
- Input voltage 88 to 264 VAC for demestic or international use
- Switching regulated power supply for reliable, constant voltage
CLEARANCE $73.98
MSRP: $87.99
2 In Stock
We'll send you an email when Mean Well RSP-320-5 300W 5 Volt Power Supply with PFC for LED Signs is back in stock or available for preorder.
