  • Mean Well MW LRS-50-12 12V 4.2A 50W Regulated Switching Power Supply AC Adapter with Power Cables
CLEARANCE Mean Well MW LRS-50-12 12V 4.2A 50W Regulated Switching Power Supply AC Adapter with Power Cables
Mean WellPart # 320-3160
Model: LRS-50-12
A reliable, fully tested power supply by Mean Well for amplifier boards, LED lights, and other 12 VDC projects requiring less than 4.2A. UL recognized design.
  • AC input range for domestic or international use
  • Built-in Short circuit, overload, and over voltage protection
  • Cooling by free air convection
  • LED indicator for power on
  • 100% full load burn-in test
  • Switching regulated power supply for reliable, constant voltage
  • UL 60950-1 approved for safety when used with 3-prong grounded AC cord (not included)
CLEARANCE $17.24
MSRP: $32.99
Save $15.75 (48%)
8 In Stock
We'll send you an email when Mean Well MW LRS-50-12 12V 4.2A 50W Regulated Switching Power Supply AC Adapter with Power Cables is back in stock or available for preorder.
This power supply is your best choice for reliable, fully tested power output for amp boards, LED lighting, and other 12 V projects. AC input range accepts from 85 to 264V operation. Short-circuit, over-load, over-voltage protection is built-in. Air convection keeps the power supply cool. 100% full load burn-in tested. The Mean Well LRS-50-12 meets UL 60950-1 safety standards.
Specifications: • Input power: 85~264 VAC, 47-63 Hz • Output power: 10.2~13.8 V, 4.2A • Dimensions: 3.9" L x 3.23" W x 1.19" H • Includes: 5 ft. 2-prong AC cord and 3 ft. DC cord with 2.5 x 5.5 mm plug.
BrandMean Well
ModelLRS-50-12
Part Number320-3160
UPC6959687380100
Weight0.8
DC Output Voltage12V
Input Voltage100~240 VAC
