  • Mean Well MW LRS-350-15 15V 24A 350W Regulated Switching Power Supply AC Adapter with Power Cables
CLEARANCE Mean Well MW LRS-350-15 15V 24A 350W Regulated Switching Power Supply AC Adapter with Power Cables
Mean WellPart # 320-3164
Model: LRS-350-15
A reliable, fully tested power supply by Mean Well for high current amplifier boards, and other 15 V projects requiring less than 24A. UL recognized design.
  • AC input range for domestic or international use
  • Built-in Short circuit, overload, and over voltage protection
  • Forced air cooling by built-in DC fan
  • LED indicator for power on
  • 100% full load burn-in test
  • Switching regulated power supply for reliable, constant voltage
  • UL 60950-1 approved for safety when used with 3-prong grounded AC cord (not included)
CLEARANCE $33.81
Save $40.18 (54%)
1 In Stock
We'll send you an email when Mean Well MW LRS-350-15 15V 24A 350W Regulated Switching Power Supply AC Adapter with Power Cables is back in stock or available for preorder.
Order in the next 6 hr 48 min to ship today. Details
This power supply is your best choice for reliable, fully tested power output for amp boards, and other 15 V projects. AC input range accepts from 90~132 / 180~264V by switch operation. Short-circuit, over-load, over-voltage protection is built-in. Forced air cooling fan keeps the power supply cool. 100% full load burn-in tested. The Mean Well LRS-350-15 meets UL 60950-1 safety standards.
Specifications: • Input power: 90~132 / 180~264 VAC by switch, 47-63 Hz • Output power: 13.5~18 V, 24A • Dimensions: 8.47" L x 4.53" W x 1.181" H • Includes: 5 ft. 2-prong AC cord and 3 ft. DC cord with 2.5 x 5.5 mm plug.
BrandMean Well
ModelLRS-350-15
Part Number320-3164
UPC6959687379951
Weight2.1
Center/Tip PolarityReversible
Current Capacity24000mA
DC Output Voltage15V
Input Voltage100~240 VAC
Plug SizeScrew Terminals
