  • Mean Well MW LRS-200-24 24V 8.5A 200W Regulated Switching Power Supply AC Adapter with Power Cables
CLEARANCE Mean Well MW LRS-200-24 24V 8.5A 200W Regulated Switching Power Supply AC Adapter with Power Cables
Mean WellPart # 320-3166
Model: LRS-200-24
A reliable, fully tested power supply by Mean Well for high current amplifier boards, and other 24 VDC projects requiring less than 8.5A. UL recognized design.
  • AC input range for domestic or international use
  • Built-in Short circuit, overload, and over voltage protection
  • Cooling by free air convection
  • LED indicator for power on
  • 100% full load burn-in test
  • Switching regulated power supply for reliable, constant voltage
  • UL 60950-1 approved for safety when used with 3-prong grounded AC cord (not included)
We'll send you an email when Mean Well MW LRS-200-24 24V 8.5A 200W Regulated Switching Power Supply AC Adapter with Power Cables is back in stock or available for preorder.
This power supply is your best choice for reliable, fully tested power output for amp boards, and other 24 V projects. AC input range accepts from 90~132 / 180~264V by switch operation. Short-circuit, over-load, over-voltage protection is built-in. Free air convection keeps the power supply cool. 100% full load burn-in tested. The Mean Well LRS-200-24 meets UL 60950-1 safety standards.
Specifications: • Input power: 90~132 / 180~264 VAC by switch, 47-63 Hz • Output power: 21.6~28.8 V, 8A • Dimensions: 8.47" L x 4.53" W x 1.181" H • Includes: 5 ft. 2-prong AC cord and 3 ft. DC cord with 2.5 x 5.5 mm plug.
BrandMean Well
ModelLRS-200-24
Part Number320-3166
UPC6959687399997
Weight1.75
DC Output Voltage24V
