  • Mean Well MW HLG-240H-24A 24 VDC 10A Water Resistant Power Supply AC Adapter IP65 Wire Leads
CLEARANCE Mean Well MW HLG-240H-24A 24 VDC 10A Water Resistant Power Supply AC Adapter IP65 Wire Leads
Factory BuyoutsPart # 129-240
Model: HLG-240H-24A
This 24 volt DC, 10 amp regulated power supply is capable of up to 240 watts of power in nearly any environment due to its IP65 water-resistant design.
  • IP65 rated chassis for use in wet environments
  • 24 VDC regulated output with 10A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Perfect for use with up to 5 meters of SMD 5050 or SMD 3528 LED lighting strips
  • World compatible grounded AC input
We'll send you an email when Mean Well MW HLG-240H-24A 24 VDC 10A Water Resistant Power Supply AC Adapter IP65 Wire Leads is back in stock or available for preorder.
This switching power supply is ideally suited for use with LED lighting. With a regulated output of 24 volts DC, and current capacity of 10 amps, this power supply is the perfect partner for up to five meters of SMD 5050 or SMD 3528 24 VDC LED lighting strips. The fully encapsulated IP65-rated case allows this power supply in nearly any environment due to its dust-free design and ability to withstand water splashing on it.
It also works with water resistant audio amplifiers that handle 24 VDC like the Lepai LWP-250.
Power input is world compatible and able to work with anywhere from 100 to 240 volts AC input. Each power supply is 100% full load burn-in tested and can handle up to a 300 VAC surge for 5 seconds. Six mounting tabs 9-1/8" apart and 12" long input/output leads facilitate permanent mounting. Edison style grounded power cord required and sold separately. CE rated design.
Specifications: • Input power: 100-240 VAC, 47-63 Hz • Output power: 24 V, 10A • Working temperature: -22° F~158° F • Dimensions: 9-3/4" L x 2-3/4" W x 1-5/8" H with mounting tabs.
BrandFactory Buyouts
ModelHLG-240H-24A
Part Number129-240
UPC848864077772
Weight2.75
