  • Max Pro The Incredible OFF Citrus Based Ink, Tar, Glue, Gum, and Scuff Mark Remover 5 oz. 2-Pack
NEW Max Pro The Incredible OFF Citrus Based Ink, Tar, Glue, Gum, and Scuff Mark Remover 5 oz. 2-Pack
Max ProPart # 341-471
Model: IR-003-043
The OFF Incredible Remover is a citrus-based solvent cleaner designed to quickly penetrate and remove tough residues like ink and adhesives. Its versatile formula makes it suitable for cleaning a wide range of hard surfaces in home, office, and technical environments.
  • Fast-penetrating solvent formula breaks down adhesives and residue for quicker cleanup
  • Removes ink, grease, tar, graffiti, and similar contaminants for multi-purpose cleaning
  • Made with natural citrus oils to provide effective cleaning with a solvent base
  • Safe on most plastics when used properly expands usability across electronics and surfaces
  • Suitable for use on surfaces like glass, metal, plastic, and countertops for broad application
  • Aerosol spray format allows easy, targeted application for controlled use
  • Sold in a pair of 5 oz. cans
NEW $23.99
We'll send you an email when Max Pro The Incredible OFF Citrus Based Ink, Tar, Glue, Gum, and Scuff Mark Remover 5 oz. 2-Pack is back in stock or available for preorder.
The OFF Incredible Remover is a citrus-based solvent cleaner formulated to quickly break down and remove tough residues such as ink, adhesives, grease, tar, and graffiti. Its fast-penetrating action helps speed up cleanup, while the versatile formula allows it to be used on a variety of surfaces including glass, metal, plastic, and countertops. Packaged in an aerosol spray for controlled application, it provides an effective and convenient solution for tackling stubborn contaminants in both home and professional settings.
BrandMax Pro
ModelIR-003-043
Part Number341-471
UPC752080030452
Weight1.1
